Flashing lights
Old Aug 1, 1999 | 11:36 PM
71SPORTCUSTOM's Avatar
71SPORTCUSTOM
Flashing lights
<center><font size="1" color="#ff0000">LAST EDITED ON Aug-02-99 AT 00:38&nbsp;AM (EST)</font></center>
Sometimes my headlights will flash on and off, at their choosing. when i bought it, they did this, but the dimmer switch was stuck on dim, i changed that and they worked for a month, no blinking. then last night they flashed a few times. I havent taken her out tonight because the rearend gear went south so i don't know if it will do it again. any ideas of what is causing this?
Nick
Old Aug 2, 1999 | 06:24 AM
Stock Man
Guest
Posts: n/a
Flashing lights
The problem is usually traced to either the switch wiring connector being loose or the switch itself. There is a safety overload in there which is designed to keep the circuit from over-heating. It weakens over time causing the blinking. If the harness connector is not loose then change your headlight switch. To change the switch you have to remove the headlight dash **** and shaft together. There is a spring loaded push button on the metal part of the switch body under your dash. Press that down and pull out the **** and shaft as one unit. Then you remove the dash bezel. Couldn't be simpler.
Stock Man
1967 Galaxie 500 Convertible (I need factory rims)
1967 F-250 FE 390 4wd
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Aug 2, 1999 | 01:58 PM
76highboy's Avatar
76highboy
Flashing lights
Check out the following techincal article:
<a href="http://www.sonic.net/~sdelanty/tools/relay">http://www.sonic.net/~sdelanty/tools/relay</a>/
In addition to replacing the switch, you might want to try this modification.
Old Aug 3, 1999 | 09:32 AM
walker's Avatar
walker
Flashing lights
<center><font size="1" color="#ff0000">LAST EDITED ON Aug-03-99 AT 10:33&nbsp;AM (EST)</font></center>
Good advice from stockman, my truck had this problem before, I installed a new switch, and fixed it. it's bad to have your lights flash off at night in a curve at 60 mph ain't it.
Old Aug 7, 1999 | 07:15 AM
dane's Avatar
dane
Flashing lights
Sounds like these other guys know what they're
talking about. I had to replace the light switch
to solve my problem.
Good Luck
Old Jun 3, 2000 | 08:45 PM
tdk's Avatar
tdk
Flashing lights
Normally the light switch will solve the problem on the blinking lights. You may also want to check for a short or an overload before you buy an new switch. I found a short in the wiring on my 81 F150 at 239K. It was easy to spot because the wires with the short were melted on the connector for the switch. I found the short under the bed where a loop of wire had rubbed agaist the frame.
Old Jun 4, 2000 | 07:40 AM
StockMan's Avatar
StockMan
Flashing lights
dpellicone
Sep 18, 2009 04:45 PM
manningjr
Delaware Chapter
Aug 13, 2008 04:14 PM
jam105
6.4L Power Stroke Diesel
Jan 21, 2008 12:04 PM
Yoson
Mar 18, 2004 09:05 PM
