a couple exaust questions
Old Jul 2, 2006 | 09:38 PM
goodwrench's Avatar
goodwrench
My current set up is first cat intact and second hollow. Then there is a short piece of 2 1/4, a 2 1/4 y then 2 2 1/4 pipes run over the axle and out under the bumper. I am comptemplating some changes. If the cats were to go missing what would be the optimal size y pipe and connecting pipe to connect to my existing y pipe and duals? i was figure maybe 2.5, but 2.25 might work too?? And then i was wondering about the 02 sensor. Does it need some back pressure to work right? or does it matter?? I am thinking about straight pipe or a glass pack muffler. I am looking for louder, and better flow. I feel the cat is holding the motor back some and might just change that, but unsure of how i want to do it.. So any other ideas on how to do it? any input of pipe size, or the o2 questions??
later!! chris
Old Jul 3, 2006 | 12:46 PM
Bdox's Avatar
Bdox
Yes, you need your oxy sensor.
You can buy high flow cats.
If you loose the cats, a single 2.5 exhaust with any free flowing muffler will work fine.
And no on the backpressure. The idea that backpressure is needed is nonsense.
jv2290
Jan 21, 2011 07:47 PM
bigredranger
Exhaust Systems
Nov 24, 2003 02:35 PM
brian_06328
Exhaust Systems
Jun 8, 2003 12:18 PM
4byford
Exhaust Systems
Nov 13, 2001 09:43 PM
