Sponsored by: Auxito
99 f150 problem
Old Jul 1, 2006 | 09:46 PM
mfraley65's Avatar
mfraley65
99 f150 problem
Heres what happened. Wife tries to start truck. It cranked for a second but before it starts the power goes dead. Open hoop. She tries to start again and the under hood light goes off and there is a clicking noise. She turns of the key and the under hood light flashes and there is a click from under the dash. She removes the key and the light stops flashing and stays on. Put key back in and there is no problem. But if the key is turned the same problem. Also, if door is open the underhood and inside and cargo light flash on and off. The clicking under the hood is coming from the black fuse box on the left firewall. Let it sit while i checked the forum and since i couldn't find anything like this i decided to try to start it again because the windows were down and it is really close to the road. Started right up. Any ideas on what might have cause this? Need to try and fix this as i don't want this to happen to me away from home.
Old Jul 1, 2006 | 10:43 PM
projectSHO89's Avatar
projectSHO89
Most likely, a bad connection at the battery, the other end of the battery cable, or one of the cables itself.
Steve
Old Jul 1, 2006 | 11:04 PM
LxMan1's Avatar
LxMan1
Or even a weak battery. Sounds like the low battery circuit is turning off the accesories due to low voltage. Check the cable connections as mentioned above and check the battery voltage.
Old Jul 2, 2006 | 09:10 AM
lariat97's Avatar
lariat97
Check your battery cable where it fastens to the starter. Mine was almost broken in two at the connection. It had 2 strands left.
jaynecobb
May 29, 2021 12:24 AM
XenonKilla
Dec 12, 2019 10:27 PM
babstinger
Sep 6, 2010 06:44 PM
lowcountry
2004 - 2008 F150
Oct 25, 2009 11:06 AM
GERRYSLM
2004 - 2008 F150
Feb 3, 2004 05:20 PM
