Instrument panel lights fuse blowing
Thats fuse 17 & it splices to ashtray bulb/rear window defrost control bulb/heat & AC control bulb/instrument illumination/radio illumination.
You said in your other post that the PO botched the job of installing a radio, so that might be where the problem is.
The connector for the radio illumination is near the ignition switch. open that connector & see if a new fuse blows.
Light blue wire with red stripe.
BearFootCustom
12-15-2010 07:08 PM
mtm1972
07-29-2004 07:19 PM
