Removing Fuse Block
My electrical gremlins appear to be a compromised fuse block, probably water damage like many others. I searched but was unable to find reference to the removal and repair. Is this a do it yourself repair? How do you get the fuse block out? This is the interior fuse block. Can they be repaired or is this a replace item?
Thanks,
Ron
µ 1. CAUTION:
Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
Disconnect the battery ground cable (14301).
µ 2. Remove the cover from the instrument panel fuse junction panel.
µ 3. Remove the lower instrument panel steering column cover (044F08).
1 Remove the lower instrument panel steering column cover bolts.
2 Remove the lower instrument panel steering column cover.
µ 4. Remove the (A) bulkhead electrical connectors from the (B) instrument panel fuse junction panel.
µ 5. Remove the (A) instrument panel fuse junction panel bolts and remove the (B) interior fuse junction panel nuts.
