Econoline pick-up 1965 tailgate
Old Jun 22, 2006 | 11:53 AM
CHUCKS65PHUGLY's Avatar
CHUCKS65PHUGLY
The bottom of my tailgate is spent (big surprise) !!!
My question is:
Is there suppose to be a tube inserted and welded to the tailgate, that slips over the tailgate mounting bracket pivot shaft ? Or did someone do a
Butch job on this ?
Was or is there suppose to be a bushing on the tailgate or mtg shaft ?
As it stands now (on mine) it looks like a tube, at one point, was welded
inside the tailgate, that slipped over the mtg bracket pivot shaft.
Now, this tube is fused/rusted onto the mtg bracket pivot shaft.
and there is a broken weld where this tube was inserted into the tailgate,
and the tailgate now is rotating on the tube.
(the tube is approx 3" long with about a 0.75 I.D. with 0.060 wall thickness)
Any explanation of the tailgate assembly would be greatly appreciated...
Old Jun 23, 2006 | 06:55 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jun 23, 2006 | 03:45 PM
Jimbare's Avatar
Jimbare
all alone in the world
yep, should be a tube welded into the end of the tailgate.
probably become part of the pivot by now, might heat it and get it loose but i doubt it.
i have used a peice of 3/4 pipe for a bushing before. would be nice if it was brass with a grease groove in it.
Old Jun 23, 2006 | 09:06 PM
CHUCKS65PHUGLY
THANK YOU !!!
I fugured as much. If I can, I'm going to fab the bottom roll
to accept a brass flanged bushing. I know it won't be stock but....
function to me, is better. I'll let you know if it fits !!!
I'l photo it before. during and after and try to post.
Cross your fingers !!! (mine too)
mbrownone
17
Apr 14, 2022 11:52 PM
DDDDDMorgan
Aug 27, 2016 03:31 PM
Afullingim
Jun 21, 2016 11:55 AM
jdadamsjr
Apr 17, 2012 08:09 PM
Hanoverfiste
1997 - 2003 F150
Oct 24, 2011 08:13 AM
