neutral kill switch
Old Jun 19, 2006 | 01:16 PM
yonu's Avatar
yonu
ok i feel stupid i just found a trans mounted one
Old Jan 19, 2007 | 10:39 PM
yonu's Avatar
yonu
ok guys I am going to bring back a really old post here but I just got a chance today to get back to wiring this as work and school has taken up all of my time.
I was able to get the backup lights working however I have been unable to hook the NSS back up the switch in the trans has 3 wires a incoming hot and out going to the bac-up lights and a thrids that I can't get a reading on in any gear any help help would be great.
oh the trans is a AOD from a 88 grand marquis
Thanks,
Yonu
Old Jan 20, 2007 | 12:19 AM
Mil1ion's Avatar
Mil1ion
I could only find this for that car.
http://www.autozone.com/servlet/UiBr...3d80103a7b.jsp
There were 3 avialable for that car .
which one did you get ?
Old Jan 20, 2007 | 12:28 AM
yonu's Avatar
yonu
well I know it isn't column mounted or console mounted as I only pulled the motor and there are are other connectors on the trans. So I suppose the donor car had console or column. Is there one for a AOD that will go in place of the backup light switch or would I need to fit a switch?
Old Jan 20, 2007 | 12:40 AM
Mil1ion's Avatar
Mil1ion
Well I have one here that came off an 80's truck.
It mounts to the C6 Transmission I wanted to know if this is what the one you have... looks like.
Old Jan 20, 2007 | 08:13 AM
yonu's Avatar
yonu
No the back up portion atleast is screwed in to the top of the trans with a 3-wire harness coming out of it
however the plug on the end is similar just more wires
that is all that is there however no other plugs or switches
Old Jan 20, 2007 | 10:01 AM
yonu's Avatar
yonu
got it sorted out I pulled the switch that is screwed in this morning there are 4 connectors on it for some reason the factory harness only had 3 so I am just going to make a harness
Thanks again,
Yonu
Old Jan 20, 2007 | 12:40 PM
Mil1ion's Avatar
Mil1ion
That's why Posted the pic to see if they may have been a wire cut off or something
I'm having difficulty finding the AODE schematic to verify it having only 3 wires to it.
Skorpion007
Jun 15, 2020 10:01 AM
snorindad
Oct 23, 2019 09:34 PM
joshua6430
May 31, 2015 08:47 PM
fzeed
13
Feb 18, 2009 04:06 PM
bullitt55
Oct 16, 2007 10:56 PM
