ok guys I am going to bring back a really old post here but I just got a chance today to get back to wiring this as work and school has taken up all of my time.
I was able to get the backup lights working however I have been unable to hook the NSS back up the switch in the trans has 3 wires a incoming hot and out going to the bac-up lights and a thrids that I can't get a reading on in any gear any help help would be great.
well I know it isn't column mounted or console mounted as I only pulled the motor and there are are other connectors on the trans. So I suppose the donor car had console or column. Is there one for a AOD that will go in place of the backup light switch or would I need to fit a switch?
got it sorted out I pulled the switch that is screwed in this morning there are 4 connectors on it for some reason the factory harness only had 3 so I am just going to make a harness
