95 psd 4x4 brake issues
Old Jun 12, 2006 | 02:59 PM
jjcustoms's Avatar
jjcustoms
Thumbs down 95 psd 4x4 brake issues
got a 4x4 psd that eats rear shoes every month, and front pads about every 2 months, replaced everything, m/c shoes drums, pads rotors, speed sensor, e-brake cables, only thing left is the abs controller, or buy a new truck. any suggestions??
Old Jun 12, 2006 | 04:07 PM
Cuda_jim's Avatar
Cuda_jim
Sounds like something is stuck. Maybe the calipers and wheel cylinders plus a fluid flush is in order.
Old Jun 12, 2006 | 06:36 PM
jjcustoms's Avatar
jjcustoms
i forgot to mention that, i have been through 2 sets of calipers and wheel cylinders, and flushed the system to go to a dot 5 fluid
Old Jun 12, 2006 | 08:13 PM
tjbeggs's Avatar
tjbeggs
did the problem start after switching to DOT5 fluid? also jack your truck up and see if the brake drag without the pedal pushed. then push the pedal and jump out and see it its hanging for a short time then releasing. also have you replaced the hoses? sometimes they get a flap of rubber that loosens up and acts like a check valve. could be your issue if the brakes are dragging.
Old Jun 13, 2006 | 03:28 PM
jjcustoms's Avatar
jjcustoms
the problem was before the fluid change, i was experienceing a little drag in the rear, but not any more with the new e-brake cables. i think i will try the flush method again and inspect the hoses. thanks
Old Jun 13, 2006 | 03:51 PM
helifixer's Avatar
helifixer
What brand of shoes and pads are you using? When I get pads for my '90 F250 at autozone they only last about 3,000 miles. on my '97 F250 I have 125,000 miles on Ford factory pads and shoes.
Old Jun 13, 2006 | 07:36 PM
jjcustoms's Avatar
jjcustoms
i've tried lots of aftermarket pads and shoes, factory ones might help, but i don't think the shoes and pads are the problem
Old Jun 13, 2006 | 07:55 PM
18vtx00's Avatar
18vtx00
possibly someone adjusted the actautor rod to the master cylinder?? can you spin the wheels? and when hot are the free to turn?? if they are grabbing that much you must have a severe overheating and pulsation w/in a few days after the work.. also use good parts not the $12 pads..
Old Jul 13, 2006 | 11:05 AM
powerstrokefreak's Avatar
powerstrokefreak
I am having the same problems and it is baffleing. Same thing, new mc, wheel cylinders, bleed, flushed. I go about two weeks before the shoes will crack and get really hot. The problem started when the truck was in the shop for a valve cover gasket swap and they went through the rear brakes. Turned the drums and new shoes and ever since it's been a nightmare. I was also wondering if the abs control valve would do this.
Old Jul 13, 2006 | 11:56 AM
Cuda_jim's Avatar
Cuda_jim
Go after the rubber hoses like tj said. The hoses develope a little flap on the inside and will hold a small amount pressure on the brakes even after releasing the pedal.
Old Jul 13, 2006 | 04:28 PM
18vtx00's Avatar
18vtx00
have you checked the master rod adjustment yet?? also the flex hoses can deteriorate after some time.. the proper way to check is drive her a few miles and get the pads hot.. then crack either end of the lines to see if it holding residual hydraulic pressure.. and the same w/ the caliper bleaders if the hoses are okay.. good luck
Old Jul 13, 2006 | 06:52 PM
powerstrokefreak
I am pretty sure that it isn't related to the brake hose. The reason for that is that the breaks dont drag just driving it down the road right after a break service. It takes about a day or two to get the shoes hot enough to crack the lining and then that start to drag. Not that it couldn't be the hose, but I would think that you would have a problem with it dragging right out of the shop instead of a day or two later. But the hose is cheap and I've got one anyway so I'll probably change it anyway and see what happens.
Old Jul 18, 2006 | 04:27 PM
jjcustoms's Avatar
jjcustoms
Unhappy
i gave up, the truck is being sold, and we got a 98 f700 crew cab instead. thanks guys
RickBraden
All Things Towing
May 21, 2012 12:21 PM
eaglestone
Dec 15, 2009 07:22 PM
RON2917
Sep 17, 2005 04:08 PM
neville123
1983 - 2012 Ranger & B-Series
Aug 7, 2004 08:44 PM
jcmac
Nov 12, 2001 07:24 PM
