Primary Brake shoe faces forward?
Old May 19, 2012 | 07:01 PM
RickBraden's Avatar
RickBraden
Took off all 4 brake assemblies on my trailer. I'm quite sure the Primary shoe faces toward front of trailer. It's my understanding that the Primary shoe has less length of pad material on metal shoe than secondary. But as I move magnet on brake as if trailer is rolling forward, it seems like the front shoe moves out toward drum. It looks like braking in reverse the back shoe extends outward towards drum. Is this correct? Thanks. It just seems backwards to me.
Old May 19, 2012 | 10:28 PM
RV_Tech's Avatar
RV_Tech
Lead shoe is the smaller of the two.
Steve
Old May 21, 2012 | 10:58 AM
r2millers's Avatar
r2millers
Rick,
To Steve's point...
When the wheel cylinder at the top of the assembly, opens or expands to initiate braking, the front shoe starts to expand as braking starts. Due to wheel rotation, the front brake pad shifts the contact with the drum, through the adjuster on the bottom of the assembly, to the rear (larger) brake pad. This shift continues until the rear pad can't move any further, once hitting the pin located at the very top of the assembly, just above the wheel cylinder. Once this happens, the complete brake assembly continues to expand and braking occurs.
Since the majority of contact thru this process occurs on the rear drum, it's size is bigger to absorp this additional braking pressure.
Hope this helps explain the difference.
Old May 21, 2012 | 12:21 PM
RickBraden's Avatar
RickBraden
Thank you r2millers. That filled in the gap I had not understanding the whole picture. I'm thankful to all the guys like you for sharing info as readily as you do.
One Sock
Jan 12, 2019 11:49 PM
RazorsEDGE
May 9, 2016 01:54 PM
Country_boy_2007
Jul 9, 2013 04:43 PM
CourierYVR
Aerostar
28
May 20, 2013 01:54 PM
JRS2
Jun 11, 2011 07:47 AM
