Towing 10000 lbs
Old Jun 12, 2006 | 12:16 PM
raptor05's Avatar
raptor05
Towing 10000 lbs
After everyones advise I finished up most of my upgrades for towing. I installed airgbags, hellwig sway bar, bilstien shocks all the way around, rancho steering stabilizer, AFE stage 2 intake, MBRP 4in exhaust with muffler delete pipe, 3 gauge pillar, and a DP-Tuner 4 posistion chip. I have had great results from all of this. Shifting is much better with the chip and the power is unbelievable. I do have a question though. What is a good temp for my tranny? Mine is about 190-200 when pulling long hills. Would a deeper tranny pan work? Thanks again for all the help.
Old Jun 12, 2006 | 02:04 PM
Monsta's Avatar
Monsta
Sit. Stay.
190°-200° is fine considering you're pulling a long grade.
Old Jun 12, 2006 | 02:13 PM
Casey's Avatar
Casey
A deeper pan would make it take longer to heat up the trans, but it would also take longer to cool once it was warm. Coolers are the only way to cool a trans. The pan is just to hold fluid, not cool it.
Old Jun 12, 2006 | 02:19 PM
Stewey's Avatar
Stewey
You pull the same weight I do. You're tranny temps are within acceptable operating parameters. No need for a deep tranny pan...IMHO.
Old Jun 12, 2006 | 03:54 PM
aklim's Avatar
aklim
I used to tow with trans temps that are 100 to 100 above ambient when it was about 80 above. Changed to the 6.0L cooler and it dropped to about 70 above ambient.
Old Jun 13, 2006 | 12:23 AM
toolboxjunky's Avatar
toolboxjunky
which bag system did u use and how much $ and how did the install go
Old Jun 13, 2006 | 11:29 AM
raptor05's Avatar
raptor05
I used the firestone bag system and it took about 2 hours. It wasn't that bad to install it made a huge difference.
Old Jun 13, 2006 | 01:48 PM
aklim's Avatar
aklim
My Ex has softer springs than the F250 and yet with the Reese WD hitch with Sway control I can do a 6000# Toy Hauler and over 1500# plus other crap of cargo in the TH without airbags.
Old Jun 14, 2006 | 09:08 AM
toolboxjunky
air bags
thks rap whick are firestone bag kit did you get?
Dutter 2
Dec 18, 2015 01:44 PM
BigBlackF-250
Jul 17, 2015 08:06 PM
Ezalycasaid
May 15, 2015 05:46 PM
jelzy
Feb 27, 2015 01:49 PM
Dutter 2
All Things Towing
Jun 25, 2014 01:01 PM
