Mods to increase/help towing capacity
So i got a 98 f150 5.4 auto tranny 4x4 and its rated for 6250 ld GVW. Now i am pushing 35s so that hurts my GVW and i want it to haul my horse trailer alittle easier. Im looking for some help on what mods of brands would be good to go with. My truck dos not have the big tow package but iv put in the electronic brakes and looking into getting a oil to air cooler for my tranny and i already have intake exhaust and just better front pads. I was looking into a towing chip for my tranny it increase line pressure and delayed up shifts and slotted rotors. Any other ideas or recommendations or brands. thanks
Well of course but i dont have a 1000 bucks for lower gears. And thats not correct, chips and shift kits help prolong a trannys life. With the higher line pressure the clutch packs get a much quicker engagement with less friction action, there for reducing the slippage in the clutches unlike stock that offer a smoother shift by slipping the clutch packs more for a better drive comfort. And a shift kit works the same but with softer accumulator valve spring to let pressured aft blow by faster to engage the clutch packs.
Go back to stock size tires works too if you have them around still.
Also service your bearings regularly with a good quality grease. You would be amazed in the difference. I just switched trailers and went to a bigger one for my quads. the bearings on the new one are as smooth a silk and the trailer tows great. The bearings in the old were good but due for a service as they were no ware near as smooth.
true.. if you go to the Chevy's with the tow/haul button that's what it does. Shifts at higher rpm and a much firmer shift.
Yeah im thinking of pulling a cooler off of a expedition because there a pretty good size and designed for the amount of atf flow i have. And well actually yeah u can compare, all hes saying is the pcm is telling that chevy tranny how to shift for towing, and the Banks shift chip will tell my tranny to do they same. All automatic trannys work about the same. You got your planetary gears, your clutch packs and you pcm/valve body to tell them when and how to shift. Untell you get into CVT trannys which they dont even put into heavy trucks. And i do plan on getting a f250 once im out of school and working, so this is just to help my truck do what it can, yes i know regearing is the best but i dont have the money or down time on my truck.
SuperDutyScaler
1999 to 2016 Super Duty
12-27-2009 12:07 PM
Jenners
07-12-2005 09:54 PM
fids
05-10-2004 04:35 PM
