Speedometer is going crazy
Old Jun 8, 2006 | 08:56 PM
somartha's Avatar
somartha
Our 96 Explorer's speedometer is not working. The needle jumps all over the place. This is causing the transmission to shift hard. We have replaced the speed sensor in the transfer case, we have replaced the rear wheel speed sensor in real axle. Any other ideas?
Old Jun 9, 2006 | 06:41 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jul 2, 2006 | 01:19 PM
jhonda650's Avatar
jhonda650
i dont know about your year, but for my year there is a recall for the speedo cable
Old Jul 3, 2006 | 03:53 PM
sjwoody's Avatar
sjwoody
I'm going to go out on a limb and assume you don't have an electronic speedometer, and that what you do have is a cable driven speedo. I have a 92 Explorer and a 94 Ranger that are pretty much identical to each other.
I'm guessing you have two problems. My 94 had a very erratic indication, which got worse as the speed went up. It stayed somewhat steady until the speed went over 20 mph, then it would jump all over with seemingly no pattern in it's fluctuations. I replaced the nylon gear where the cable goes into the tranny with no help. I'd have to do a search and find out who here on FTE recommended a speedometer rebuild to me, since I don't remember. He was absolutely right when he said the jewelled bearing that the needle rides on wears out and causes this problem. I removed the instrument cluster from the vehicle (not an easy job) and had it sent to a "speedometer repair shop". $143.00 later it works perfectly and there was no need to mess with the odometer.
As for the shifting hard issue, my truck did it before the repair, and it's still doing it after...I think that's another issue that I have to deal with.
Old Jul 3, 2006 | 03:57 PM
sjwoody's Avatar
sjwoody
Here's the link to the thread...hope it works
https://www.ford-trucks.com/forums/s...d.php?t=493473
Follow the link given by CowboyBilly
dlsoc3
Sep 8, 2022 03:16 PM
Stevenbowman23
Mar 23, 2015 12:12 AM
mbee
Nov 14, 2013 07:35 PM
86moneypit
1997 - 2003 F150
May 14, 2013 10:46 PM
kd7ptn
Apr 11, 2011 06:59 AM
