Still having speedometer problems...
Old Apr 10, 2011 | 03:28 PM
kd7ptn's Avatar
kd7ptn
Arrow Still having speedometer problems...
My speedometer on my 88 f150 4wd is not reading properly. it reads 0 on a medium to heavy throttle. and at highway speeds with a very light throttle it reads 40-45mph, bouncing all over.
I checked the speedometer cable and lubed it.
I also replaced the Speed sensor.
does any one have any other suggestions?
Old Apr 10, 2011 | 04:35 PM
Lazy K's Avatar
Lazy K
Could be a bad speedo cable drive gear or even a bad gear on the transfer case output shaft.
Old Apr 10, 2011 | 04:50 PM
kd7ptn's Avatar
kd7ptn
when I replaced the speed sensor, i did observe the speed cable gear. i didn't notice any broken teeth. but I did notice the gear appeared to be cupped and worn.
when I first bought this truck one thing I noticed was the speedometer operated at 5mph below the actual speed. this due to my tire size. i am running 31x10.50Lt AT
Old Apr 11, 2011 | 06:59 AM
Lazy K's Avatar
Lazy K
You may need a new speedo drive gear (you can get one to correct the speedo error).
Maybe attach a power drill to the end of the speedo gear and see if the speedo reads steady, just to confirm that there no cable problems.
ech0sh4y
Jul 9, 2017 07:47 PM
emgee
May 8, 2017 03:12 PM
Paul Bostic
2004 - 2008 F150
Feb 7, 2017 07:54 PM
Ebrown2469
1997 - 2003 F150
Feb 18, 2016 01:33 PM
juanjayala7
1997 - 2003 F150
Jun 4, 2010 01:22 AM
