carb
Old Jan 23, 2002 | 03:21 PM
Ford Trucks Rule's Avatar
Ford Trucks Rule
carb
[updated:LAST EDITED ON 23-Jan-02 AT 04:22 PM (EST)]On a 68 f100 360cid. I want to get my carb rebuilt. But the tag is gone on it so i dont know what type it is. There is a little sticker on both sides that has a bunch of numbers and says holley on it. So whats an easay way to find out what rebuild kit i need.
Thanks
Old Jan 23, 2002 | 05:36 PM
Mil1ion's Avatar
Mil1ion
carb
[updated:LAST EDITED ON 23-Jan-02 AT 06:39 PM (EST)]
2 BBL or 4 BBL ?
also,looking at the linkages ,etc
Does it appear to be original?
Dennis
Oh....Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=144&.jpg
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=143&.jpg
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Jan 23, 2002 | 05:40 PM
Ford Trucks Rule
carb
2bbl,On the label it also says rubuilt by Holly. Yea the linkage does look kinda old.
Old Jan 23, 2002 | 05:52 PM
Mil1ion's Avatar
Mil1ion
carb
[updated:LAST EDITED ON 23-Jan-02 AT 06:56 PM (EST)]Is the name Holley cast into the carb anywhere?
How about Ford cast numbers?
Anything to get close to year and make.
I have a motorcraft service kit for 1968 Holley 2 BBl
CT-186A
Dennis
Old Jan 23, 2002 | 07:21 PM
William's Avatar
William
carb
FTR, If you don't mind a little advice. Work on the ignition system first. Swap your distributor for a remanufactured one (50.00) and install the Pertronix Ignitor electronic system (75.00). Then add the big flat cap, long nose rotor and adapter (junk yard and 40.00). Install some 8mm fat wires (30.00) and a set of bosh platinium plugs (25.00). If you have a few more bucks add a mallory or similar coil (80.00). Gap the plugs at 80. You can do all this work yourself, with minimal tools and not all at once. Do new plugs and the pertronix first. I'll bet your carburator is fine for now. I am assuming you have clean fuel and air filters, oil changed, PCV and crank case breathers in order.
William in Atlanta
Old Jan 24, 2002 | 11:08 AM
Ford Trucks Rule
carb
I just got a new distribuotor and coil. Its single point. But i do not have a pcv setup correctly... like burnt oil always comes out of the left valve cover
Old Jan 24, 2002 | 06:09 PM
mk's Avatar
mk
carb
Does that carb ahve a removeable float bowl on the front or does it have a top cover plate/ air horn assembly? If it has the top cover, you'll find a Ford part number stamped on the front left side of the bottom flange (ie-C8TE-A).
Old Jan 24, 2002 | 07:45 PM
oleblue70's Avatar
oleblue70
carb
WVTOMMY
Feb 8, 2012 08:07 PM
71FoMoCo
May 4, 2009 09:08 AM
steamin441
Feb 12, 2007 06:24 AM
dcexplorer
Nov 23, 2003 08:09 PM
78fordman
Oct 30, 2003 01:23 AM
