Bendix steering Vs. Saginaw
Old May 30, 2006 | 02:33 PM
PROSTOCK's Avatar
PROSTOCK
You have the prop valve correct, it is for the rear brakes. The confusion may be due to the front reservoir being for the rear brakes the rear reservoir for the front...just guessing there though.
Old May 30, 2006 | 02:37 PM
zebrastud57's Avatar
zebrastud57
so is the front area always going to be for the rear brakes regardless of the size of the front reservoir?
Old Jun 4, 2006 | 08:03 AM
walkhaulsey's Avatar
walkhaulsey
This might be a little late. You changed you cloumun and messed with your linkage rods , did you at any point mess with your clutch rod adjustment or any other component that pertains to your clutch? If your clutch does not enagage all the way, that would make it a little difficult to shift. Perhaps your through out bearing is wearing.
Old Jun 4, 2006 | 09:42 AM
zebrastud57
i haven't done anything with the clutch, it seems like the trans mission is loading up when it shouldn't.
Old Jun 5, 2006 | 08:57 AM
PROSTOCK's Avatar
PROSTOCK
Always is a strong word. But I would say in most cases, yes. And with almost certainty all Ford units would be.
Fhtagn
Oct 23, 2016 02:19 PM
FordStolz68
23
Feb 12, 2016 05:01 AM
ET3RNAL
31
Dec 26, 2015 03:24 PM
TBird Larry
Sep 23, 2014 02:37 AM
Order and Chaos
Aug 12, 2014 08:41 AM
