Power Window Kit
Old May 25, 2006 | 10:28 PM
yellow78ford's Avatar
yellow78ford
Power Window Kit
I'm really considering getting the power window kit from the LMC catalog for my 78 f150. Sure, it will take away for the truck's origional stock crank handles but I can care less. I drive the truck daily and with rising temps and no a/c, it would be nice to just hit a button. I have also heard of others using oem stuff from 80's Fords but I honostly don't want to take the time to find the stuff and modify.... I just want to install it. The lmc kit sounds like a direct bolt in kit. Anyone have this kit? How is the quality, installation, and use?
Old May 28, 2006 | 07:23 AM
classic79's Avatar
classic79
there is one company that actually has a new regulator i think its electiclife or something like that. more expensive but it pretty much duplicates a oem setup.
Old May 28, 2006 | 07:32 AM
79F150EFI's Avatar
79F150EFI
I was also looking at these kits, so I am interested if anyone has an experience with this as well.
Old May 30, 2006 | 02:36 PM
supercab78's Avatar
supercab78
I've installed the electiclife system. The window regulator was a direct bolt in and seems well made, no plastic cables or tape. The part that takes the longest is doing the wiring and switch installation. I used their harness and switches. The switches I use are the kind that stand off the door panel a little, this allowed me to cover over the hole for the crank. The stand off that holds the switches are black just like my door panel so it likes as if it was original. It's been in my truck for 4 years and no problems. There was no instructions for the installation of the (switches)in you door panel as for as location or hole size so cut small you can always go bigger.
Old May 30, 2006 | 05:53 PM
Sgt Wonderful's Avatar
Sgt Wonderful
Supercab, how about some pictures of your electric window installation..
Old May 30, 2006 | 09:36 PM
77f2504by4's Avatar
77f2504by4
http://www.a1electric.com/Merchant2/...ct_Code=FD41-K
is this the kit you are talking about? this is the rout i was thinking of taking.
Old May 31, 2006 | 07:21 PM
STGFordCrazy04's Avatar
STGFordCrazy04
in my 1950 F1 I used a power window system but I forgot the name brand which would help alot. This kit used the original window crank but the regulator was the switch. What I mean is pull the crank up approx 10* and the window goes up push it down 10* past 0 and the window goes down. Really cool because I didnt have to cut or modify anything and someone who doesnt know would never know they were power windows. Anyone help me with the company? I found it in a hot rod magazine.
Old May 31, 2006 | 07:26 PM
yellow78ford
Originally Posted by 77f2504by4
http://www.a1electric.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=AEOS&Product_C ode=FD41-K
Nope, I am talking about the kit offered by LMC truck. http://www.lmctruck.com/icatalog/fc/0061.html It's cheaper than that kit you posted and it offers the wiring and switches which that kit does not offer.
Old May 31, 2006 | 10:00 PM
supercab78's Avatar
supercab78
Sgt Wonderful:I've never posted pictures yet but I'll see what I can do on Thursday.
Old Jun 1, 2006 | 09:59 AM
1975Ford's Avatar
1975Ford
A buddy of mine bought this kit from LMC. The kit from A1Electric have less moving parts and require less mounting hard ware.
Old Jun 1, 2006 | 01:56 PM
leadmic's Avatar
leadmic
The LMC kit is a universal kit that has a lot of monkey motion. I would be afraid of the durability of that kit. Their was a guy on this board that was adapting a electric motor from a 80s Ford to a 70s regulator with good success, you might try searching, he had pictures in his gallery. I'm going to adapt one or but the A1 kit myself.
Leadmic
mb1096
20
Dec 12, 2019 01:29 AM
Wyowanderer
Oct 2, 2010 07:12 PM
78_f800crewcab4x4
Jan 31, 2008 10:29 PM
Farmall05
1978 - 1996 Big Bronco
Feb 21, 2007 07:53 PM
