Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Homemade CNC machine
Old Jul 26, 2006 | 08:42 AM
  #91
Torque1st's Avatar
Torque1st
Posting Legend
I shake too bad to hold any size tip within 1/2 inch of where it needs to be. Even holding a propane torch flame on a battery terminal and hitting it with solder was difficult. Got it done by bracing my hands and arms against parts but it took a long time and a lot of solder hit the ground. Didn't have to wait for the son to have time tho...
Old Jul 26, 2006 | 06:47 PM
  #92
frederic's Avatar
frederic
Some more progress in the wiring today, but no pictures yet. The PC, the controllers, and the interface are done, tested, and passed "quality control" (i.e. nothing caught on fire!).
Now, to wire the machine. Getting closer to sourcing the chain-shroud-thing that covers the wiring, allowing it to flex in one direction only so it doesn't fall into the machine and get plasma cut.
The coolest thing (wiring wise) is the panic button. Push the panic button, and instantly the plasma cutter will shut off, the steppers will stop on a dime, AND the software will pause rather than keep going. This allows for the highly improbable situation where something went seriously wrong, yet the work is salvageable.
Old Jul 26, 2006 | 10:46 PM
  #93
Torque1st's Avatar
Torque1st
Posting Legend
Every machine needs a "Panic Button" or "E-Stop". Getting the software to pause is good.
Some manual jog or movement buttons would be nice also. They would have to work thru the software.
Old Jul 26, 2006 | 10:59 PM
  #94
frederic's Avatar
frederic
To test the steppers and drivers, I manually actuated them using pushbuttons with a simple debouncing circuit - all is good. Not sure how to do it through the software, but maybe there's a setting that anytime the machine is paused (e-stop), it automatically rezero's itself once the pause feature is released.
I'll figure something out I'm sure.
frederic
40
Dec 28, 2021 02:54 AM
frederic
Jul 16, 2021 09:01 PM
frederic
Garage & Workshop
16
Nov 29, 2006 02:05 PM
frederic
Jan 5, 2006 07:58 PM
frederic
New Jersey Chapter
Sep 22, 2005 07:58 PM
