272 blues
Old May 20, 2006 | 07:50 PM
haul_n_hover's Avatar
haul_n_hover
272 blues
I'm trying to get a 56 272 running for my Father in law. First, can I put on a later model 2bl carbeurator? In some of the other posts they talk about using a 57 distributor then converting it to an electronic set up. I went to the usual places, Autozone, Napa, etc.., and didn't find the one they were talking about. Which is better, keep the original, and get one of the electronic sets from classic auto parts, or change it out then upgrade it? Then there is the fuel pump, is it dual action or single action? Thanks for any help help you can give me.
Old May 22, 2006 | 07:49 AM
312's Avatar
312
you need the 57 up intake for newer carb same goes for dist,.
Old May 22, 2006 | 03:44 PM
haul_n_hover
Thanks for the info. Will an intake from a 292 or 312 fit the 272? And how much should it run me? Thanks again.
Old May 22, 2006 | 09:46 PM
Homespun91's Avatar
Homespun91
First of all, welcome to FTE!
In terms of an intake, a) yes, a 292 or 312 intake will fit the 272; depending on what you get, the ports may not be the same size. They will work though.
b) If you were wanting a 4bbl. intake, as 312 says, the '57 intake is the desired one. ECZ-9425-B is the casting; it has the "Holley" or "squarebore" flange. The going rate on eBay is $75 or more, these days. All other 4 bbl. intakes use the older "teapot" carbs.
c) I'm not too up on the 2 bbl. intakes, but again as 312 says, I believe any '57-'64 2 bbl. intake will accept a newer style carb. They are dirt cheap, & can often be found on the Bay with a decent rebuildable carb attached. An intake by itself...I wouldn't pay over $25, & more like $10. Nobody wants 'em as a rule, so buy accordingly. Keep in mind the shipping might be more than the intake cost.
d) The '57-up distributor is what you want. Everybody sells the Cardone-remanned unit these days from what I've seen, though it's often re-boxed under different brands. The NAPA part is NRD 48-2808 for $51.49, with a $33 core charge. The AutoZone # is 30-2808 (all of 'em have the 2808 identifier from what I found some months back), for $43.99/$20 core. I have not seen the AutoZone unit in person, so there may be a quality difference, there may not. Probably going to be a special order item anywhere you look.
e) If you get the '57-up dizzy, then any electronic kit listed for Ford points (single point, that is) V8 '57-'74 will work. Accel, Mallory, Crane, Pertronix, & others all make kits. The Crane seems to be a good unit & runs about $65, others are around the same, or up to $100 or so.
f) If you keep the '56-earlier dizzy, then I believe Pertronix makes the only electronic kit for it. Not my choice for distributor or kit mfg., but others here have had good luck with the Pertronix kits.
g) No idea what fuel pump he has, but any Y block fuel pump will work...although it may not look the same, & you may have to fiddle with lines & fittings to hook it up. As a matter of fact, the FE pump is the same thing, so you can even get a high performance pump, to feed that 2 bbl. If this is a restoration & he needs something specific, I can suggest a couple of places to try, but a thread a few weeks back indicated that finding a NOS (new old stock) pump at a swap meet or eBay was probably the best bet.
Hope it helps...
Old May 23, 2006 | 04:05 PM
haul_n_hover
Again, thanks. And no, I don't really want to keep the 2Bl carb, just want to get the thing running for the least amount of money.
Thanks
Joe
Old May 23, 2006 | 08:23 PM
phjbbu's Avatar
phjbbu
If you're trying to get it running, I don't think I'd start by tearing out the ignition system and throwing in a Pertronix (or whatever other kind). The suggestion here is to get it running first then do the discretionary items.
Old May 23, 2006 | 08:57 PM
46yblock's Avatar
46yblock
Good point!
Old Jul 3, 2006 | 11:30 PM
haul_n_hover
no more blues, just a big grin
Just wanted to say thanks for all the info. I went ahead and rebulit the carb., and it fired up. I didn't have time to rebuild the generator and find a new voltage regulator. So I made a few modifications to the top bracket and made a new lower bracket and mounted a single wire GM altenator. Again thanks for all the help.
skotyg
13
May 28, 2014 05:36 PM
dmpruss
1978 - 1996 Big Bronco
May 12, 2009 12:21 PM
Extacie
Apr 22, 2009 10:59 AM
cortez
Mar 7, 2004 04:39 PM
jim smith auto
Sep 4, 2003 09:18 AM
