1954/56 Y blocks used the 4V Holley 'teapot' carb. The teapot and its intake manifold mounting holes are different than the 1957 and later 4V manifolds that used the Holley 4V 'double pumper.'
ECZ-9425-A is not the manifold's part number, it's the casting number which cannot be cross referenced to a part number, so I have no idea what year it's for.
Odd duck: 1955 272/292 4V: The automatic choke is mounted on the intake manifold, not on the carburetor!
All of the intakes with the "A" after the casting # that I have seen have the small carb pattern. Modern 4 bbls won't work on those. They were for early Y blocks as ND said.
I have one of them you can have if you really want one.
Scott, you want the ecz-9425-b , fits the modern carbs. You'll also want to change your distributor to the 1957 and up style so you have centrifugal advance and vacuum advance. I have 3 of those b intakes I'm in Pa. Dennis
You can buy an adapter to change from the teapot style carb mount to the Holley. Speedway has them for under $30. Then you have a cheap intake with a newer Holley.
Correct, but, now you have a 4v set up that flows about as well as a 2v set up
The "B" intake is a night and day improvement over the "A" intake
