shuddering...
Old May 17, 2006 | 01:23 PM
1983_f100's Avatar
1983_f100
shuddering...
i havent had any problems with my 300 except when i went to crank it today it started and all but it shook the entire truck pretty bad and i dont have a clue what it could be...anybody know? i do need to change the oil probably though since gramps probably didnt lol...is that it?
Old May 17, 2006 | 08:19 PM
Bdox's Avatar
Bdox
Get a reading on your plugs and post the result. What year?
Old May 17, 2006 | 08:30 PM
1983_f100's Avatar
1983_f100
and how exactly do i "get a reading from my plugs"? sorry im a newb and its a 1983 lol
Old May 17, 2006 | 09:21 PM
Bdox's Avatar
Bdox
Just remove the plugs and examine them.
If all is well they should have a uniform light tan color.
Since it was shuddering, it sounds like a misfire and the color can help you determine the cause. Post back with your results.
Did it smooth out after it ran a little while?
Old May 18, 2006 | 09:28 AM
1983_f100's Avatar
1983_f100
no it didnt smooth out...thats exactly what it was because i remember it backfiring...so just look at the spark plugs and change if em need be?
Old May 18, 2006 | 10:56 AM
Bdox's Avatar
Bdox
We don't have much to go on. Looking at the plugs is to try to see what's wrong. If they are the same, if you have a rich (black) or lean (white) condition. The plugs rarely go that bad suddenly unless something broke.
The backfire is new information, was it through the intake or the exhaust?
Look carefully at all the hoses connected to the intake to see if any have come off or broken.
Old May 18, 2006 | 11:19 AM
1983_f100's Avatar
1983_f100
im wantin to say the exhuast....
Old May 18, 2006 | 11:32 AM
1983_f100's Avatar
1983_f100
ok so i took the wires off the end of the plugs and everything looks fine but i started it again and every time it fires it sounds like its spitting something and my oil is getting kinda chunky
Old May 18, 2006 | 12:47 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
You need to remove the plugs from the engine and look at the firing end.
A slight brownish to grayish tan tent to them is normal.
Ash deposits, light brown, almost white deposits encrusted on the plugs. suggests new valve guides are needed
Black is rich, or oily deposits. suggests new valve guides or rings are needed, or the fuel mixture is off.
Your oil is getting chunky? Is it tuning white? metal lumps?
Old May 18, 2006 | 12:52 PM
1983_f100's Avatar
1983_f100
they look like metal lumps...and im at work now so ill have to get back on around 5 to tell you what the plugs look like...
Old May 18, 2006 | 04:08 PM
1983_f100's Avatar
1983_f100
yep...spark plugs are good..talked to my dad and he said that when we were bringing it home that it did that and it was fine once he got on the highway and its been fine ever since wednesday...
Old May 18, 2006 | 08:15 PM
81-F-150-Explorer
I would definatley change the oil, and possibly have it tested.
Metal lumps suggest mechanical damage inside the engine of some kind.
If you have a Computer. Run the codes.
It could be a sticky EGR perhaps, or a faulty Ported Vacuum switch.
At least the plugs are normal, thats a good sign at least.
Old May 19, 2006 | 08:49 AM
1983_f100's Avatar
1983_f100
yeah i was really glag that they were good...and im sure my grandpa hadnt changed the oil in a while so thats on my to do list for tomorrow morning
Old May 19, 2006 | 11:57 AM
1983_f100's Avatar
1983_f100
btw thanx everybody for the help
midsouth
Nov 5, 2012 08:34 PM
ZOOT
37
Aug 26, 2010 08:57 PM
fordmarshall111
May 11, 2010 02:03 PM
Ford F1Fool
May 12, 2008 06:29 AM
billemc
Feb 9, 2005 07:15 AM
