fuel filter
Old May 16, 2006 | 09:23 PM
fordboy2's Avatar
fordboy2
fuel filter
Im buying a 2000 f250 crew with the 7.3 and want to change the fuel filter right away as I dont know when it was changed last, is that the only filter the little tiny one along the frame rail? I ask this beacuse I have had several duramax's before having trouble with my 05 and buying the fords and they had bigger spin on filters. If it is, does anyone make a better aftermarket to replace this thing? It seems kinda wimpy!
Old May 16, 2006 | 09:43 PM
clux's Avatar
clux
The fuel filter is under the hood on top of the engine towards the passenger's side.
The fuel pump is on the frame rail.
Old May 16, 2006 | 10:01 PM
piotrsko's Avatar
piotrsko
I myself lust after the pre 99 spin-on's.
There are other filter kits/media available, but unless you are getting routinely bad fuel, I see no reason to change the stocker for aftermarket. The spin-on's don't allow you to drain the water out, and if you keep getting bad fuel , would advise switching brands or stores. The stock filter seems to keep most of the crud out of the injectors as I have not heard of any complaints here on the FTE site in perhaps 6 -8 months. Changing it often seems to be the best prevention-- every 10 K miles is about right for me.
Fleet Autozone, Napa et all have a bunch of inexpensive elements. do a search on the term fuel filter.
Old May 16, 2006 | 11:18 PM
jtharvey's Avatar
jtharvey
If you have a small one under the framerail, it's most likely something that a previous owner added, since the truck doesn't come with one there stock. The only stock one on yours is in the valley of the engine, towards the front, right behind the HPOP resivoir.
If you wanted to add an aftermarket one, you can get some that are fuel/water seperators as well. I have a Dalh 150 unit installed on my truck. You can see pictures of it in my gallery. Since I have a suitable filter and water seperator on the truck, I have removed my stock fuel bowl entirely, both because it's no longer necessary and in preperations for installing a BTS dual HPOP.
Old May 17, 2006 | 10:11 PM
7.3powerstroke's Avatar
7.3powerstroke
I have found that the best place to get fuel filter and also oil filters is fleetfliter.com Check them out
Old May 18, 2006 | 09:53 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I believe the indirect injection engines (pre 94) have spin on filters, but the 94.5-97 PSD has virtually the same filter as yours. Actually they are quite a bit different, but it is a replaceable element type that mounts in the same location as yours.
Old May 19, 2006 | 09:27 AM
piotrsko's Avatar
piotrsko
OK so I lust after a pre 94 filter. I stand corrected
Must have been aftermarket.
MauleOne
Oct 19, 2011 12:24 PM
ArcticF250
Apr 24, 2010 09:50 AM
07250psd
Jul 6, 2009 08:20 PM
UGA33
Oct 15, 2006 11:41 AM
pollok
Aerostar
13
May 10, 2004 04:51 PM
