Power Steering Lines
Old Apr 30, 2002 | 09:11 AM
mdadster's Avatar
mdadster
I Have a 71 F100 with power steering and the lines from the pump to geer box are oozing fluid thru the rubber. I have considered cutting the metal line and clamping new rubber hose from the line to the pump. Can I do this or is there too much pressure in these lines?
Any help would be greatly appreciated!
Old Apr 30, 2002 | 09:36 AM
buzzard's Avatar
buzzard
This would be a great time to completely flush your system. Disconnect the return line (plug the fitting on the back of the pump and disable ignition) and crank the engine over while catching the old fluid in a pail. Keep refilling the pump until the fluid runs clean. Then replace the pressure line and return line from the gearbox to the pump for around $25.
To answer your question though, don't try to mend the pressure line.
Old Apr 30, 2002 | 03:51 PM
LonnieD's Avatar
LonnieD
That bring up a question I've been wanting to ask. My Power Steering unit making a "clacking" sound when she idles. I have a 69 F250 /390 (newer engine).. It does seem when it clacks it will stop if I turn the wheel and put it under stress. Should I seek a new unit (junkyard tyoe) or I hear you can get re-build units or is the nosie from the pulley bearing?
Lonallie@cs.com
lonnie.dotson@boeing.com
Old Apr 30, 2002 | 05:21 PM
Hawkeye58's Avatar
Hawkeye58
My pump was doing the same thing (making noise).
Soon after I'd discovered the noise, the pump started leaking at the front as well. I'd replace that pump if I were you. Go to your nearest parts store and get a rebuilt one. Roughly 60-70 dollars.
You will be pleased with the results.
Hawkeye
Old May 1, 2002 | 10:06 PM
dan79's Avatar
dan79
The clack could be belt noise. Try to take the glaze off of the belt to see if it helps or get some water on it to see if there is a change in noise. I have had that problem on two of my trucks. Just something to check and rule out.
Dan 69 F-100 302, C4
Old May 1, 2002 | 10:12 PM
jwtimme's Avatar
jwtimme
My pump made noises at idle it was cracking like you all are describing. I changes pumps like 3 times befor I found one that did not make noise, Oreily's has a lifetime warenty on their rebuilt pumps for like 40 bucks.
Old May 7, 2002 | 09:11 PM
CRJ900's Avatar
CRJ900
Old May 10, 2002 | 02:13 PM
LonnieD's Avatar
LonnieD
Who or what is:Oreily's ... tahnks for all the help guys
Lonallie@cs.com
94xlt150
Feb 8, 2015 09:26 PM
Fordman96
1978 - 1996 Big Bronco
Sep 14, 2013 10:42 PM
Lee Lichterman
Nov 4, 2006 11:54 AM
GeneStoner
General Automotive Discussion
Jan 31, 2005 06:30 AM
GSchretter
Sep 30, 2002 06:40 PM
