Replacing Power Steering Gear.
Old Sep 29, 2002 | 07:23 PM
GSchretter's Avatar
GSchretter
On replacing the power steering gear on a 87 f-150 2X4 with a 302,
Question :
Does the steering wheel shaft slip on and off easily after losing the the bolt that combines the power steering box to the steering wheel.
I can easily take off the three bolts that hold the power steering box and the two lines for the power steering pump. Looking at the connection from the steering wheel shaft to the power steering box look like you might have to hold open something with rubber gaskets to get the power steering box out of the steering wheel connection.
I read the hayes manual and it just states to REMOVE and INSTALL but nothing about if there is some kind of lock besides a bolt CLAMPING them together.
THANKS..
Old Sep 29, 2002 | 09:02 PM
91f250460's Avatar
91f250460
Should just slide in and out once the bolt is taken out. Replaced the gear box in my buddies 95 ranger the other day. Make sure that when you reinstall it that the shaft slides back in far enough, and don't forget to locktite that bolt.
Old Sep 30, 2002 | 02:20 PM
GSchretter's Avatar
GSchretter
Thanks...
Good idea about lock-tight..
Old Sep 30, 2002 | 06:40 PM
madman666's Avatar
madman666
jjlrrw
Nov 24, 2020 08:38 AM
19fifty4
Apr 14, 2016 05:53 AM
99expyTN
6.4L Power Stroke Diesel
Oct 28, 2014 12:07 AM
PSDBOWHUNTER
Feb 16, 2011 05:03 PM
FordF350Baby
Sep 5, 2009 09:25 PM
