1978 - 1996 Big Bronco
fuel pressure regulator?
Old May 7, 2006 | 05:12 PM
blackened's Avatar
blackened
after i shut my truck off a few seconds later you can hear a strange noise coming from somewhere towards the rear of the intake. i put my ear close as i could to the FPR and it seems to be coming from there. its a hard sound to describe as no pings knocks buzzes rattles could describe it. well maybe buzzing. it sounds more like an old computer working its hardest or screwing up. could this mean its going bad orrrrrrr is it clogged orrrr is that just the sound it makes relieving pressure? im not too keen on the fuel system.
on another note, i bumped the timing up and ran sea foam through the intake and this increased my power by ten fold. i thought i was having transmission problem but after setting this and my idle the best i could i can feel a tremendous change. i recommend both these tricks to anyone looking for a cheap way to restore lost power.
Old May 8, 2006 | 12:01 AM
greystreak92's Avatar
greystreak92
With the engine off and cold (just in case) remove the vacuum line from the FPR. If there is fuel in the regulator or the line is wet with fuel, the FPR has a problem.... otherwise, unless you are haiving hard starting issues or power loss issues, I'd leave it alone.
Old May 8, 2006 | 08:40 PM
kameronth's Avatar
kameronth
Ya, those fpr can be hard to get to if that is the problem. I will never forget replacing mine.
Old May 9, 2006 | 05:05 PM
JBronco's Avatar
JBronco
Where is the FPR? I've got sudden hard starting issues all of the sudden, it always starts but it has to crank long. But if I turn the key on and off a couple of times to run the pump before starting, it starts right up. This started after I put some fuel system cleaner into a full tank of gas but that is nothing new or unusual although it was a different one than I usually use (it was name brand though, Gumout I think). Does this sound like it might be a FPR issue?
Old May 11, 2006 | 02:06 PM
kameronth's Avatar
kameronth
I am not sure if your issues are the FPR but it you follow the fuel rail on the drivers side it is near the fire wall. It is silver(usually) and has a vacuum line going into it. There are three little screws that hold it on.
Old May 11, 2006 | 02:35 PM
JBronco's Avatar
JBronco
thanx I'll check it out. If it's not too expensive perhaps I'll just replace it. Although from what I'm reading it is a PITA???
Old May 12, 2006 | 08:32 AM
InkDawg's Avatar
InkDawg
Mine takes like 3 minutes or so to change...it depends on the year of your Bronco....mine the screws are on top but older Broncos I think the screws come in from the bottom and are harder to get too...
Old May 12, 2006 | 09:40 PM
JBronco's Avatar
JBronco
How much do they cost? I have a 1990 5.8
Old May 12, 2006 | 09:59 PM
blackened's Avatar
blackened
44.99 at oreilly
Flatbed Ed
6.2L V8
Mar 2, 2015 08:22 AM
jbounds
15
Jun 24, 2013 06:21 PM
CNC
Nov 3, 2010 06:55 AM
nomorecummins
6.4L Power Stroke Diesel
Jun 26, 2010 07:22 AM
UaVaj
Aug 7, 2008 07:47 PM
