RE Grinding starter
Old May 6, 2006 | 11:40 AM
Ford150/428/dud's Avatar
Ford150/428/dud
RE Grinding starter
Last week i posted about having my starter drive go out for no apparent reason, Well i got a new one to replace it and today put it all together and put the starter on the motor and it worked just like new. I shut it off and went to get some tools to adjust the timing and i came back to start it and the starter drive made a grinding sound just like it did the first time now its teeth are missing again. What it causing it to do this?
Old May 6, 2006 | 07:11 PM
Torque1st's Avatar
Torque1st
Posting Legend
Bad/wrong flywheel.
Old May 6, 2006 | 09:36 PM
Ford150/428/dud
I pulled the inspection tin off and the fltwheel looks good. The problem that baffles me is that it worked just fine last year when i took the engine trans and transfer case out of the truck in one piece. I never took the engine off from the trans. It must be something in the starter.
Old May 7, 2006 | 01:55 AM
roger dowty's Avatar
roger dowty
were you able to inspect all the teeth in the flywheel? You could be missing a small section and whenever it engages in that spot it will eat your starter.
Old May 7, 2006 | 08:45 PM
Ford150/428/dud
I think i found the problem I looked at one of my parts trucks and the starter that was on the motor causing the problem looked totaly different. The biggest difference was that the starter that was causing the problem had the bottom bolt hole reamed out way to big. compared to the starter on the parts truck. Im thinking the previous owner cobbled up the starter to work. because it never caused problems before i took it off the engine. So i replaced it with the starter from the parts truck and it works just fine now.
Old May 7, 2006 | 10:15 PM
Torque1st's Avatar
Torque1st
Posting Legend
So essentially the teeth were positioned too far apart and only partially engaging??? Sounds like you may also have the wrong starter.
Old May 10, 2006 | 08:47 PM
Ford150/428/dud
i LOOKED IT UP IT WAS THE WRONG STARTER. Yes i hate it when things are cobbled up. I think it was either not engaging or getting too close to the flywheel. Thanks for the help
birchwoodford
Mar 22, 2012 12:16 PM
96F150HuntingTruck
Apr 21, 2011 10:37 PM
berlincam86
33
Feb 27, 2011 07:16 PM
dondonsmyname
Sep 10, 2010 08:59 PM
moe waltner
Jan 4, 2010 10:11 AM
