Mirror Adjustment???
Old May 4, 2006 | 04:29 AM
slychicken37's Avatar
slychicken37
I have a 1983 F150 with the stock mirrors. I was wondering if there is a way to adjust the tension in the little ball joint.
My problem arrises when I set the mirror in place, then a minute of driving it is looking at the ground from the vibration.
I would rather not replace the entire assembly if at all possible.
Let me know,
-Rex Buchanan
Old May 4, 2006 | 08:33 AM
Sycostang67's Avatar
Sycostang67
If you have the swing arm style mirror, I dont know of any adjustments that can be made. I know you can replace just the head if need be, without replacing the entire arm.
Old May 7, 2006 | 01:15 AM
howler's Avatar
howler
on the bottom of the mirror near the pivot usually are 2 phillips head screws, if you tighten the screws, it will tighten the pivot
Old May 7, 2006 | 04:43 PM
tsoca's Avatar
tsoca
you can get new mirrors for the swing arm style at any truck stop for around $8. and pep boys has the whole assembly for $30/side
PAf250
Nov 23, 2015 08:58 AM
DvlRacer
Apr 6, 2015 06:31 PM
LYTEMUP
Dec 22, 2013 02:35 PM
whistle1516
Jan 10, 2012 08:21 AM
BKeyes
Dec 3, 2001 02:54 PM
