Mirror Glass Won't Adjust Inward?
Old 03-21-2015, 05:43 PM
DvlRacer's Avatar
DvlRacer
DvlRacer is offline
DvlRacer is starting off with a positive reputation.
Is this common? When I bought the truck the passenger mirror adjusted every direction except inward but the driver's side worked fine. The other day after having it inspected the inspector backed the mirror into the garage door and now the driver's side adjusts every direction except inward as well. Is there an easier fix to this instead of replacing both mirrors completely?
Old 03-21-2015, 06:59 PM
DieselDenny
DieselDenny is offline
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
Jump out of the rig, manually push the glass in the direction it won't travel. Then get on the mirror stick and see what you see.
When I hit brush or run into something, it works for me.
Denny
Old 03-21-2015, 07:57 PM
DvlRacer's Avatar
DvlRacer
DvlRacer is offline
Denny
Tried that, just went out and tried again. I was wrong though, both mirrors refuse to adjust RIGHT, which is inward on driver's side and outward for passenger side. That makes me believe it's likely the switch that's the culprit. Anyone else had a similar issue?
Old 03-21-2015, 08:31 PM
whitetmw
whitetmw is offline
whitetmw is a name known to allwhitetmw is a name known to allwhitetmw is a name known to allwhitetmw is a name known to allwhitetmw is a name known to allwhitetmw is a name known to all
Since your having problems with both, check the Switch with a DVOM, you should see system voltage. If you do not, replace the switch.
Old 04-06-2015, 06:31 PM
DvlRacer's Avatar
DvlRacer
DvlRacer is offline
New switch did the trick, thanks
TNT in Round Rock
1999 to 2016 Super Duty
161
01-29-2017 04:21 PM
cobrafromhale
16
12-31-2016 08:38 PM
BDPohl
Electrical Systems/Wiring
05-26-2016 02:05 PM
The_Lawn_Guy
1997 - 2003 F150
03-06-2008 10:45 PM
Steve Ingalls
Ranger & B-Series
08-15-2005 10:12 PM
Quick Reply: Mirror Glass Won't Adjust Inward?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
