Bronco II Ford Bronco II
Lifting the Bronco 2
Old May 2, 2006 | 08:29 PM
86broncoboy's Avatar
86broncoboy
Smile Lifting the Bronco 2
hey everyone. i have a 86 bronco 2. new paint job, seats, dash, exhaust, and rebuilt engine and now i am looking to lift it 6 in and put 35's (33 if i have to) on it. any advise on lift companies and/or how to go about doing this the right way the first time?
Old May 2, 2006 | 09:31 PM
RomerB2's Avatar
RomerB2
Well if you haven't swapped in a bigger rear than the stock 7.5" rear then you're in trouble running 35"s for very long, you'll snap the axle if you're not carefull. Same way with your front end, I believe you have a Dana 28 or something like that which isn't very strong. If you were to get a donor vehicle (Explorer) you could swap in a D35 front and 8.8" rear I believe just from that one truck.
As far as lift companies I'd go with James Duff or Superlift. I installed a Rough Country, and it's OK, but not that great, some of the holes didn't bolt right up so I had to make my own, but it was fun making it all!
Old May 3, 2006 | 07:11 PM
rebocardo's Avatar
rebocardo
imo, 33s are way to large for the stock running gear.
A perfect combination is a James Duff (www.jamesduff.com) suspension lift and
31x12.50x15 tires. Once you break the Dana 28 or 7.5 rear you can alway swap to the Explorer axles.
Old May 3, 2006 | 08:19 PM
RomerB2's Avatar
RomerB2
You wouldn't be as likely to snap with 33's as you would with 35's but either/or you're still talking about a chunk of rubber as rotating weight.
Does Duff make larger lifts than 3"? I haven't looked into them that much.
Old May 5, 2006 | 08:13 AM
oppy's Avatar
oppy
Skyjacker makes a great lift also. Kinda pricey tho - I don't have one because I'm way too cheap!
If I was gonna buy a lift it would be either Duff or SJ.
Old May 5, 2006 | 07:12 PM
OSin86's Avatar
OSin86
I'd go with a 3-4" suspension lift and a 2" body. That's a good combo that won't totaly kill your wallet. If you are going 35" then I too would get rid of that D28 in the front and I'd start looking for an 8.8 for the rear.
Old May 8, 2006 | 11:15 PM
Monty06's Avatar
Monty06
right now jd makes 5-6inch lifts for 4wd trucks
on my truck i have right now 31x10.50 lt15 but i'm changing to 33x12.50lt15
i have 4.10 gears with a d28 and 7.5 i have a d35 and 9.9 being rebuilt as i write.
Old May 8, 2006 | 11:22 PM
Monty06's Avatar
Monty06
8.8 gears i meant sorry oops
Old May 14, 2006 | 03:21 PM
Help I M Stuck's Avatar
Help I M Stuck
I got a 86 Bronco II with 4inch suspension and 3 inch body lift and run 35x12.50x15 BFG MT/s and been offroading with it every/every other weekend for 3 years now with no problems. I don't blaze thru mud holes..all i do is general trail riding and easier rock crawling with it.
kaytor692
Bronco II
Mar 24, 2012 01:56 AM
jacobjacob86
Bronco II
Oct 27, 2011 10:12 PM
Kalashtar
1978 - 1996 Big Bronco
Jun 13, 2006 12:19 AM
86bronco2jeff
Bronco II
Nov 7, 2002 05:29 PM
nickc84
Bronco II
Aug 20, 2001 10:42 PM
