Bronco II Ford Bronco II
86 b2 lifts
Old Aug 26, 2011 | 07:58 PM
kaytor692's Avatar
kaytor692
86 b2 lifts
i have a 86 bronco2 that i am looking for a small lift for now. im looking at a 2' pro comp lift it is a 2" block under the coil spring and a helper sring in the rear. my question is will this afect my front end alignment caster camber all that good stuff
Old Aug 27, 2011 | 07:38 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to FTE........stick around...we will get yon u aanswer
Old Feb 12, 2012 | 05:30 PM
Clint1973's Avatar
Clint1973
i have 2 of the metal twist in blocks from autozone on each front sping on my BII, doesnt bother my alignment
Old Mar 7, 2012 | 08:48 AM
mudslinging79's Avatar
mudslinging79
do you have a part number for the autozone parts?
Old Mar 24, 2012 | 01:56 AM
Mr.Offroad's Avatar
Mr.Offroad
Having been a front end guy for about 10 years, I can tell you this: anytime you change ride height with the suspension on the "Traction Beam" Ford front end, it will change your camber, and usually a little toe-in change as well. Just a good idea to have it checked afterward. I like the biscuits under the coil springs, as it doesn't affect the ride, and the twist-in spacers sometimes will fall out on a real rough road, and will fatigue the springs over time. Just my two bits!
881504x4
Mar 7, 2006 01:02 PM
Johnny0
Oct 20, 2005 09:58 AM
sdbobbie007
Jul 23, 2004 02:27 PM
orange peel
Jan 17, 2002 11:31 PM
