Bronco II Ford Bronco II
Suspension Lift for a bronco II with a CV joint driveshaft
Old 08-20-2001, 03:17 PM
nickc84's Avatar
nickc84
nickc84 is offline
I have an 86 bronco II with a three inch body lift. I tried to suspension lift it, but I have a CV joint drive shaft and the lift put a bad bind on it, making it pop. I am wondering what kind of options I have to lift it without changing out any major parts.
"Speed equals money how fast do you want to go?"
Old 08-20-2001, 10:40 PM
kold_phuzhun's Avatar
kold_phuzhun
kold_phuzhun is offline
There's no easy way to say this, but if you're screwed. You need a new U-joint drive shaft in 2 parts. U-joint because, well, no body makes/likes CV shafts that I know of and their so much better. And the 2 parts because that's the only way for the driveline to extend the way it needs to. You can find pre-builts relatively cheap, but that's about your only option.
Old 08-20-2001, 10:42 PM
kold_phuzhun
mdr617
Bronco II
01-19-2011 08:31 AM
Fordman18
09-08-2010 05:48 PM
BigTony
Bronco II
07-01-2005 02:58 PM
badazb2
Bronco II
10-15-2004 12:10 PM
HaveSomeFanta
Bronco II
02-13-2004 06:54 AM
Quick Reply: Suspension Lift for a bronco II with a CV joint driveshaft
