Additives?
Old May 1, 2006 | 12:33 PM
AustinS's Avatar
AustinS
I use Stanadyne Performance Formula in the summer and winter, and the DK spring and fall. It's pricey compared to others, but I get a real 2-3 mpg. increase over any other additives I have used. It helps smooth out the rough winter and it shines in the summer heat when my truck gets its worse abuse.
I love everything about all Stanadyne products excep for the $$$. Same goes for BG products too. Quality costs more because its worth more.
Austin
Old May 1, 2006 | 02:05 PM
Bigtrucknuts's Avatar
Bigtrucknuts
where do you get this stanadyne stuff?
Old May 1, 2006 | 08:55 PM
Lushman's Avatar
Lushman
The only place I found the Stanadyne near me was Camping World. The problem was they only had a small bottle and it was very expensive. Search online and you will find thier websites or try to email them.
Old May 1, 2006 | 10:12 PM
jtharvey's Avatar
jtharvey
Here's where I get my Stanadyne. I use the Performance Formula.
http://www.se-power.com/index.cfm?Ca...Name=Additives
Old May 2, 2006 | 05:57 AM
superrangerman2002's Avatar
superrangerman2002
Whoa, Whoa, Whoa!!!
Back in the day when diesels had mechanical injectors and such, a qt of ATF was a decent idea, but not so any more!!!
ATF is probably the worst thing to dump into a modern diesel motor, the stuff really plays havoc on the injection system.
Atf is not highly detergent as many like to believe.
Please vist the Oil and Lubrication forum or BITOG before dumping ATF into your tank.
AlaskanF350
Jan 8, 2014 01:37 PM
bluescrew
24
May 10, 2010 10:01 PM
kw5413
Nov 6, 2009 03:32 PM
Bigtrucknuts
Sep 4, 2006 07:04 PM
Chris R
Jan 19, 2000 08:30 AM
