Lower Racetrack Molding
Old May 1, 2006 | 12:14 PM
beartracks's Avatar
beartracks
I've heard several times that "so and so" would start making it but to my knowledge no one ever has. Many of us would like to get the parts. I suspect they are hard to produce.
Old May 1, 2006 | 03:33 PM
broke77f100's Avatar
broke77f100
sorry...no luck...if my truck had it i'd a sold it to u cheap
Old May 2, 2006 | 06:33 PM
mspooner's Avatar
mspooner
Originally Posted by 79f250camper+Lar
did you find the molding? im looking for the same thing.
No, I give up. Going to have the body shop clean up and repaint the black strip on the old stuff. Too bad considering what I figured out I have into the paint and everything that I replaced is close to $10000. Oh well I will replace it when new stuff is available.
Old May 2, 2006 | 08:19 PM
Mil1ion's Avatar
Mil1ion
Make sure they use semi-gloss.
Old May 4, 2006 | 03:50 PM
wintremute's Avatar
wintremute
Here's a start for you NOS
ebay# 8062230129
I think that's for the drivers side front fender
Old May 6, 2006 | 10:15 PM
mspooner's Avatar
mspooner
Thanks,contacted them and they only have the one piece.
Old May 9, 2006 | 07:36 PM
rescuedranger's Avatar
rescuedranger
ebay# 8062230129
Thanks for the tip, I got it for 33 bucks delivered, that is the only piece of molding I needed for my truck.
I just got a fender I bought off of Ebay, no dents no rust and even the right color, for 82 bucks delivered!
Now all my truck needs is a new paint job, motor, transmission, steering column, vacuum booster, tires, etc:-)
I'm bringing her back from the edge, hence the name;-)
Old May 10, 2006 | 12:06 PM
just1me's Avatar
just1me
racetrack moulding
I dont know if you have checked them out but www.paddockparts.com has the racetrack moulding listed and their number is 1-800-428-4319
I know because I have their catalog and its listed on page 47, and it labeled and shows the racetrack moulding.
Old May 10, 2006 | 12:15 PM
Mil1ion's Avatar
Mil1ion
upper or lower ?
Old May 10, 2006 | 12:54 PM
just1me's Avatar
just1me
moulding
In the catalog it has a diagram Im not sure I think its the upper ,but it also shows lower peices to that go around the wheel wells and along the bottom of the truck,I guess you would have to call and ask them. The part numbers I see listed tough are I think they are for the bed.
D7TZ 9929038FA (RH 6 3/4 w black insert)(racetrack style)
D7TZ 9929039FA (LH 6 3/4 w black insert)(racetrack style)
D7TZ 9929038EA (RH 8 w black insert)(racetrack style)
D7TZ 9929039EA (LH 8 w black insert)(racetrack style)
Old May 10, 2006 | 04:34 PM
Mil1ion's Avatar
Mil1ion
That is the upper moulding for 6.5 ft boxes and 8 ft boxes.
Although the center area of the lower moulding has black in it ....it isn't an insert
The search continues
Old May 10, 2006 | 05:23 PM
just1me's Avatar
just1me
more
I found a better place National Parts Depot has race track moulding listed from the front to the back I have there catalog and was flipping thru it today it shows it listed for the fenders,doors, cab,bed, the number is 1-800-368-6451(North Carolina) 1-800-874-7595 (Florida) website address is
www.npdlink.com
F-16003-6 (RH front fender upper race track style) call
F-16004-7 (LH front fender upper race track style) 99.95
F-20878-2 (Front door outside lower RH or LH race track style 77-79 super/crew cab,reg cab) 99.95
F-20938-3 (RH front door outside upper,race track style) 69.95
F-20939-3 (LH front door outside upper ,race track style) 69.95
F-423A16-3 (RH Backpanel side upper,race track style)(reg/crew cab) call
F-423A17-3 (LH Backpanel side upper,race track style)(reg/crew cab) call
F-29038-5 (RH,LB race track style) (box side upper) call
F-29039-5 (LH,LB race track style) (box side upper) call
F-29038-6 (RH,SB race track style) (box side lower) call
F-29038-7 (RH,LB race track style) (box side lower) 124.95
F-29039-7 (LH,LB race track style) (box side lower) 124.95
F-29038-8 (RH,LB race track style) (box side lower) call
F-29396-1 (RH,L shaped,race track style)(box side rear) call
F-29397-1 (LH,L shaped,race track style) (box side rear) call
This is all I found listed.
Old May 10, 2006 | 06:07 PM
  #28
wintremute's Avatar
wintremute
Glad I could help!
Old May 10, 2006 | 08:51 PM
  #29
Mil1ion's Avatar
Mil1ion
Just1me,
That still isn't the correct moulding.
Thanks though.
Have you seen the picture of the moulding to know what we are talking about ?
Click the link in post 14 and see the chrome loulding with the painted black track inside of it that starts where it meets the other racetrack moulding at the side marker light on the box then follows the contour of the wheelwells to the front of the box.
This moulding in question is what seperates the two colours of the truck.
Old Jul 6, 2006 | 09:06 PM
  #30
dude74crew's Avatar
dude74crew
NO ONE CARRIES THE LOWER molding. That is a fact. Dennis Capenter will have it if anybody does.
The tooling equipement is still around but they will not reproduce it.....
mystery....
LARIAT 85
107
Aug 26, 2025 08:45 PM
toddclem
Oct 14, 2011 02:57 PM
SuperDuty93
Aug 1, 2011 03:51 PM
johaner78
Nov 18, 2007 07:37 PM
johaner78
Paint & Bodywork
Nov 17, 2007 02:35 PM
