Any Suggestions
Old Apr 26, 2006 | 12:47 PM
300-6's Avatar
300-6
Arrow Any Suggestions
Okay, I am finishing a motor transplant, i started with an 87 4.9 ans I am replacing with a an 88 4.9l. The motor is sitting happing in it's new home, but i have few problems. When I start it up, it runs real rough shakes and sounds like it has miss to it. The exhaust fumes smell like it's running RICH. I have went back and checked to make sure everything is pluged in. I am thinking that I may have some vacum lines crossed somewhere, I followed the diagram in the manual but I am still unsure. If some one has some pics on their engine compartment they would be great. Any Ideas
87 F150 4x4
4sp 4.9l
Thanks
Old Apr 26, 2006 | 10:32 PM
4.9inline6's Avatar
4.9inline6
is it timed correctly? distributor in there correctly?
chris
Old Apr 26, 2006 | 10:34 PM
beatupford's Avatar
beatupford
If its efi your talking about, could be over 1000 reasons. I guess i tell you what everones telling me, pull the codes. Somethings might be effecting manifold vaccum, so your map sensors out of range? vacuum check valves not working, Throttle position sensor? EVP sensor? Bad compression? Check voltage reference to your your sensors. As for vaccum lines, could be a leak. If you do that it might pinpoint the problem down. If you like danger blow a little propane gas (very little so it can dissapate quickly) on all vaccum connections and gaskets on a COLD engine. Its very effective, and your rpms will go way up if you have a leak.
Old Apr 27, 2006 | 08:11 AM
300-6's Avatar
300-6
I am going to check the timing tonight. The thing that worries me is the strong amount of exhaust gas, the cloud is real thick it's hard to describe it's a real, dark thick cloud. I am going to check the temp sender;s tonight, and the timing.
Maybe I will figure it out
Old Apr 27, 2006 | 11:37 AM
81fordf-250's Avatar
81fordf-250
there are so many
There are so many possible causes to this it isn't even funny. Electric fuel injection can have one little thing wrong and mess the whole thing up. It could be the egr valve the maf senser or map senser bad injectors or bad o2 senser. The best way to find the cause is with a computer.
Old Apr 27, 2006 | 11:50 AM
300-6's Avatar
300-6
I am about ready to just tear everything of the top, and put a carb on. I am sure all the smog garbage isn't helping things.
Old Apr 27, 2006 | 02:40 PM
81fordf-250
if u want
The efi will get better gas mileage than a carb
Old Apr 27, 2006 | 04:48 PM
300-6's Avatar
300-6
True, but their is not as many things to contend with.
But more then likey I will figure it out.
I HOPE
Old Apr 27, 2006 | 08:24 PM
optikal illushun's Avatar
optikal illushun
sounds like she may have a vacuum leak. u can always try going around the engine and spray come carb cleaner (or the like) to see if it clear up at all.
i would also check fuel pressue and check engine vacuum with a guage. use this site: http://www.users.bigpond.com/ergoff/vac1.htm for references and how to test. (there is two pages).
good luck.
Old Apr 28, 2006 | 08:15 AM
300-6's Avatar
300-6
Well I finally figured it out last night, It was combo of two things. 1. The map sensor was partially unpluged. 2. The collant sensor on the back of the block was unhooked. but the main thing is it's running now. Now all i need is new exhaust.
Thanks everyone's help
t mango
13
Jun 3, 2015 09:35 PM
Boss Hogg 87
Feb 2, 2013 07:14 AM
zimmzala
Jul 21, 2011 06:37 AM
allwaysoffroadin
Jul 4, 2008 06:13 AM
tonyperiat78
17
Aug 29, 2006 07:26 AM
