Electrical Issues
Old Jan 31, 2013 | 10:30 AM
Boss Hogg 87's Avatar
Boss Hogg 87
Electrical Issues
I have an 87 F-150 4.9L and I am having some issues with the battery charging. I have had the alternator replaced and the battery has been tested so both are good, but my voltage gauge reads nothing (it might just not work) and my battery light is now on. When I drive at night with the headlights on it drains the battery after a while so it is not be charging while the truck is running. I have heard people talk about a voltage regulator but I am not sure if I have one or where it might be. I'm also not sure if that's the problem. I would appreciate any help anyone can provide
Old Jan 31, 2013 | 12:10 PM
AbandonedBronco's Avatar
AbandonedBronco
I don't remember if they went to alternators that have built in voltage regulators, but if not, then that's probably it. I had this same issue on my '81 and that fixed it. The voltage regulator is an (approx.) 3in x 3in box on the fender next to the battery. They're about $20 new.
Old Jan 31, 2013 | 12:27 PM
rustywheel68's Avatar
rustywheel68
just thinking out loud-
maybe the trigger wire on the regulator (the one that tells the alternator to start charging) isn't connected? unsure on the '87, but i think these wires were usually green. should be the "I" wire.
Old Jan 31, 2013 | 03:04 PM
Boss Hogg 87
Thanks a lot guys! I'm hoping its just that trigger wire because The battery light came on after I hit a really rough patch in a road so maybe it jiggled loose.
Old Jan 31, 2013 | 07:22 PM
dustybumpers's Avatar
dustybumpers
that's a 2 g set up, known for melting the harness that plugs into the alternator.
To test the key wire, it is the green/ red tracer wire. My bet is diode in the alternator went bad from bad connection. You can replace the connection with a harness patch, or go ahead and up grade to the newer 3 g set up. I have been doing that with all my g2 trucks as they start to give me problems.
I have a g3 install thread if anyone is interested in the upgrade, I will look it up, and post a link
Old Jan 31, 2013 | 08:22 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
There should be a fuse link in the harness as well. Check the continuity on all the wires in the harness to be on the safe side.
Old Jan 31, 2013 | 09:04 PM
Mike451's Avatar
Mike451
I would be very interested in looking at the 3g install thread
Old Feb 1, 2013 | 05:43 AM
dustybumpers
Fuseable link, black/ orange tracer, comes off the solenoid
I'll find it and link it when I get home later
Old Feb 2, 2013 | 07:14 AM
dustybumpers
Ok, here is the thread I spoke of. there are others, but this one will give you the basics. The whole thread is a good read, but I started the swap instructions on page 3, or post # 32, depending how you have your browser set up.
https://www.ford-trucks.com/forums/1...ator-help.html
Let me know if you need any other info
Dads76XLT
50
Oct 13, 2016 05:01 PM
Muddy86F150
Electrical Systems/Wiring
Feb 11, 2010 06:56 PM
bigperm2
16
Dec 9, 2008 11:23 PM
Psyte
18
Sep 15, 2006 02:44 PM
1982fordf100
May 18, 2004 06:26 PM
