Steering Rag-Joint Help
Old Apr 23, 2006 | 01:24 PM
1969fordtruckman's Avatar
1969fordtruckman
I have a 1969 F100, and the ragjoint it torn. I need to replace it.
I need to know a few things:
1) Will a 73-79 ragjoint work
2) Is it something I can do myself? How hard is it?
3) What do I need to do it?
Old Apr 23, 2006 | 04:54 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 23, 2006 | 06:11 PM
jor's Avatar
jor
It's pretty straightforward. Just undo the bolts on the rag joint and on the column collar. Then, from inside the truck, pull your steering wheel back enough to get the rag joint out. Clean it all, apply a little grease and put it back together. On mine I had to also remove the brake line bracket to avoid lacerating my hands even more than usual.
jor
Old Apr 23, 2006 | 06:14 PM
1969fordtruckman
jor
Thanks! I'm glad it is something I can just buy the part and do myself. Thanks.
Old Apr 24, 2006 | 09:08 PM
nomadic's Avatar
nomadic
The rag joint on my old 71 custom looks pretty good...however, I was pretty proud of the truck, since I had spend a few hundred buck on its appearance, so I drove it to Church one Sunday.....Parallel parked in front of the church...Could not manipulate it out of the parking space until the other cars moved....So embarassed that I certainly would not drive it back to church....and don't even get it out of the garage to often...other than the rag joint, and adding power steering...How can I help the steering on this old truck...anyone know anything.....it has new tires, etc......!
Old Apr 24, 2006 | 10:08 PM
jor's Avatar
jor
My advice: Either get power steering or start workin' out! I'm a purist and insist on leaving my manual steering unmolested, however, with each passing year I am reconsidering this decision. I live in Tucson and never have to parallel park or I might just bite the bullet and go power. The trick is to do all the turning while the truck is rolling - kinda tough in your position at church.
jor
emeraldcoupe
WTB - Parts & other
Jun 9, 2014 09:22 PM
66F250CS
43
Dec 16, 2013 08:09 PM
DirtyCustoms
Mar 11, 2013 08:28 PM
tom42nm
Mar 13, 2012 09:24 PM
fmc400
Feb 14, 2009 08:16 PM
