Oil pump primer?
Old Apr 19, 2006 | 08:24 PM
1982fordf100's Avatar
1982fordf100
Oil pump primer?
As I continue collecting parts for my 300 build up, whats good to use to prime the oil system on a new 300? I know the drive shaft is 5/16. Can I just use a long 5/16 rod to spin the oil pump or do I have to buy an oil pump primer tool? Thanks
Old Apr 19, 2006 | 08:48 PM
300I6VAN85's Avatar
300I6VAN85
I built my I6 in my garage this year, my first motor build. A buddy made a pump primer tool from round bar stock. He heated it, took a hammer to it and ground it to look like a screwdriver blade. Not what I had in mind, but you don't look a gifted horse in the mouth. It did fit snug. I put a drill motor on it and let it spin. I started to get the ****** because I had a vision of this make shift tool making small shaving in my motor. I pulled all the spark plugs, put the dist. in, and cranked the motor over with the starter after that. I have heard of others using a old dist. shaft. That is what I would do if I have to do it again. That reminds me. I have a old dist. now that I went to a dist. with vacuum advance.
Old Apr 20, 2006 | 09:33 PM
Wik's Avatar
Wik
I cut off a 5/16 allen wrench and stuck it in a 5/16 extened quick connect to reach into the distributer hole. Worked great. Just don't drop it in.
Old Apr 20, 2006 | 10:15 PM
havi's Avatar
havi
I'll have the Roast Duck
cordless drill with an allen socket put on a cut-off 1/4" nut-driver rod(cut off the handle end)
Old Apr 21, 2006 | 03:29 PM
1982fordf100
Thanks for the input guys. Sounds like anything that will spin the oil pump will work. I just didn't want to have to buy something if I can make something. One more question. When your spinning it which way does it go, clockwise or counter clockwise? Thanks
Old Apr 22, 2006 | 11:08 AM
83Van's Avatar
83Van
There's a very easy no-fab solution. The drive shaft just slides out of the distributor, so chuck it up in a socket & extension and you're good to go.
Rotation is clockwise.
Old Apr 22, 2006 | 08:53 PM
61F750's Avatar
61F750
Cranking it with an old hand brace they used to use with auger bits will work too. You can crank it at different speeds and watch the oil ooze all over th rockers. Cheap entertainment.
Old Apr 24, 2006 | 08:25 PM
javi2001's Avatar
javi2001
Disconnect ignition coil and remove spark plugs, then just use the ignition swith, it will spin fast.
Old Apr 25, 2006 | 09:18 AM
81fordf-250's Avatar
81fordf-250
no don't crank it !
If you do that it is the same as a dry start. The old way works best because the motor doesn't turn.
Old Apr 25, 2006 | 02:43 PM
javi2001's Avatar
javi2001
Yes old way is the best but this not same since there is no power production at pistons, no torque no nothing just bearing surface floating over film of oil used prior to assembly parts.
dirtfrmr57
25
Apr 15, 2017 11:18 AM
LowBudgetF250
Jan 31, 2017 01:49 PM
Daddyo's garage
Jun 15, 2016 03:29 PM
TrippingCobras
17
Apr 25, 2012 08:58 AM
PaysonPSD
21
May 6, 2010 07:05 AM
