223 Duraspark conversion
Old Jun 15, 2014 | 05:23 PM
Daddyo's garage's Avatar
Daddyo's garage
Just finished installing the modified Duraspark distributor into my 223 six. Man that works slick! Got a new gear from Mac's and had it resized to fit the new distributor. Also had the 5/16" oil pump shaft stepped down to 1/4" for the pump.( the 5/16" rod cost me $1 for 12", enough to make 3 shafts!) Got the distributor, cap, rotor, wires, and control module from AutoZone. Lifetime guarantee! Got V8 wires to get the right length. The ones from the 300 six were too short. Distributor must be in the center on them. Same price! And I have spares in case...
The old six feels much more responsive, and no more lag! Well worth the cost!
Next up.... Alternator, A/C, new rear end.....oh, and rewire under the dash with a fuse box. Got most of the parts....just need the time!! =-O
Old Jun 15, 2014 | 06:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Is the Duraspark dizzy one with mechanical advance as well as vacuum? Is the shaft you had downsized from 5/16 to 1/4 a hex drive?
Old Jun 15, 2014 | 06:16 PM
Daddyo's garage
Yes and yes! Electronic ignition too!
Old Jun 15, 2014 | 06:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
When I traded out my Load-A-Crapic to a similar mech/vac dizzy, it felt like I bolted on 20 HP. I can imagine it's the same for you!
Old Jun 15, 2014 | 06:49 PM
Daddyo's garage
Yup! It's awesome! Now I need to find a deal on a two barrel manifold, carb and headers! Anyone got them for sale?
Old Jun 14, 2016 | 10:50 PM
pholmes350's Avatar
pholmes350
What year Duraspark did you use? Part #? Thanks.
Old Jun 15, 2016 | 01:26 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
DuraSpark ignition modules are identified by a colored plastic square above where the wires feed out. The most popular and reliable has a blue plastic square.
If this is what was installed, I'll edit the particulars into this post.
Old Jun 15, 2016 | 03:29 PM
pholmes350's Avatar
pholmes350
Well I've tried twice to buy a 300 distributor part 30-2610 and both vendors have refunded my money. Turns out this was probably a good thing since I don't think that's the dist. that I really wanted. Is there another part/model number of the 300 dist. that can be adapted to the 215/223 by modifying the drive gear.
Matthew_Jones
13
May 10, 2017 12:29 AM
MP&C
Apr 25, 2009 01:19 AM
ryanstoy
Apr 25, 2007 10:59 PM
OzarksFord
Oct 2, 2005 11:40 AM
