Sponsored by: Real Truck
Stuck Tow Mirror
Old Apr 17, 2006 | 05:57 PM
lusher21's Avatar
lusher21
Stuck Tow Mirror
Well, my passenger side manually extendable tow mirror extended just fine the last time...but now it is stuck and I can't push it in. I smacked it pretty good a few times, but no go. I suspect I have to take it apart somehow. Anyone else had any experience with this problem? Thanks.
Old Apr 17, 2006 | 08:22 PM
jake00's Avatar
jake00
cant be frozen (water / ice) could it?
Old Apr 18, 2006 | 03:21 AM
cowboylukas's Avatar
cowboylukas
I have the same problem with my passenger side mirror as well. It has been that way since I bought it back in August. Has anyone been able to fix this problem? Please assist.
Old Apr 18, 2006 | 09:29 AM
zx250's Avatar
zx250
Of the next Riffraff East
I helped a buddy of mine fix his. His mirrors folded both ways. We folded it out to 90 degrees from door and while he put steady pressure inward I gently tapped on the arms with a rubber mallet. We also sprayed armorall on the slides and inside as much as we could. Alternate between top and bottom. We came to the conclusion that he must have over extended it. It took a little effort but it eventually broke loose and now slides like it should. Maybe this will work for you to.
Old Apr 18, 2006 | 10:12 AM
lusher21's Avatar
lusher21
Thanks Jake...but if this baby is frozen, all the weather prognosticators here in San Diego have lost their jobs.
O.K. ZX, I'll get out the rubber mallet.....
Old Apr 18, 2006 | 12:40 PM
akford351's Avatar
akford351
Are they supposed to slide in and out freely?
I've tried moving mine in/out before and nothing...
Old Apr 18, 2006 | 01:57 PM
Munkey's Avatar
Munkey
Older (Early99-Late99?) tow mirrors don't extend out.
Old Apr 18, 2006 | 02:10 PM
zx250's Avatar
zx250
From what I can tell on Fords web site, extendable tow mirrors is an option. You may not have extendable mirrors. Mine did not have them until I tore one of and had to replace them.
Old Apr 18, 2006 | 03:45 PM
cowboylukas
Mine definately has the extendable mirrors. My drivers side one goes in and out...however the passenger side is stuck in the "out position" Any Suggestions?
Old Apr 18, 2006 | 04:08 PM
akford351's Avatar
akford351
Yeah... I must have just regular ones then.
shaffecv
Mar 14, 2017 06:04 PM
VocaTexas
Dec 9, 2016 01:42 AM
porthole
6.7L Power Stroke Diesel
13
Dec 19, 2015 07:42 AM
emmagator
May 18, 2015 01:32 PM
tbirdrick
Oct 29, 2004 10:14 AM
