2.02 valves....
Old Apr 17, 2006 | 12:02 AM
EgoMan's Avatar
EgoMan
2.02 valves....
I was wondering if I can run 2.02 valves in my 351? I know stock it wont work...but the new motor is bored .060 over with big valve reliefs so im not sure. I want to run AFR 185's....
Old Apr 17, 2006 | 12:18 AM
TigerDan's Avatar
TigerDan
The problem with running valves that large in stock heads is that the valves are so close together that they touch, so 1.94/1.60 is pretty much the limit for stockers. The AFR 185s are designed to use 2.02/1.60 valve combo, so you should be good to go there. Be sure to check piston-to-valve clearance with whichever cam you'll be running.
Old Apr 17, 2006 | 01:46 PM
EgoMan's Avatar
EgoMan
Yea i was reading that with 2.02's you have to put a little notch in each piston .100'' deep. I know I have some nice size valve reliefes but wasnt sure if they were in the right place.
Old Apr 17, 2006 | 06:15 PM
TigerDan's Avatar
TigerDan
They should be in essentially the right place for anything but Twisted Wedge heads, they bigger question is if they are large enough diameter. You need to put one rod/piston in the motor and set the head in place with a used gasket of the same thickness you'll be running and clay the piston to check piston-to-valve clearance and valve relief size/location. Better than finding out after the short block is assembled and having to tear it all apart again to cut the valve reliefs larger.
Old Apr 17, 2006 | 06:27 PM
EgoMan's Avatar
EgoMan
Ahh too late for that......lol its all togeather. I guess I could run the 165cc and use the 1.94 valves they still flow more than the edelbrocks.
Jrf100
Jun 3, 2012 05:35 PM
Gibby55
Jun 2, 2011 05:27 PM
1bad67sbf
24
Apr 11, 2010 01:45 PM
novadragman2005
Feb 11, 2006 12:42 PM
fordeverpower
Mar 10, 2005 09:52 AM
