I am building my engine to be a weekend warrior. It is currently a stock 96' 351w. I am going to do the following mode and want to keep the truck running on 91 pump gas.
With a stock piston and a 62cc head you should be around 9.5:1. Thats me going by what I have read. If you had dome pistons with those heads then your compression would be alot higher. The set up you have will be fine on 91 gas.
