Does anyone have this installed? I know it goes on with double sided tape, but as to how to make it centered, how does one go about doing so? I am pretty sure I seen it done on someone's gallery, but I forget the member's name. Thanks
the roush scoop comes with a template you lay on the hood to mark the place to drill 4 holes for the studs. I put a piece of 2" tape down the center of my hood and measured from the sides to the center to get a center line then taped the template and drilled the holes, placed the the hoodscoop on and double checked the alignment then I added the double face tape and bolted it down. Pretty easy took me a couple of hours just because I wanted it perfect.
