engine oil capacity
Old Apr 16, 2006 | 05:51 PM
someday's Avatar
someday
engine oil capacity
my 89 e250 with a 302 5.0l engines is supposed to take 6 qts with an oil and filter change...for some reason i have to use 7 qts
Old Apr 16, 2006 | 06:10 PM
jroehl's Avatar
jroehl
Are you parking on a level surface when you check? Is everything stock--dipstick & tube, oil pan and pump? Are you draining the oil with the engine hot or cold (supposed to do it hot)?
And, are you remembering to put the plug back in before you fill? (I've only forgotten once, I only lost the first quart )
Jason
Old Apr 16, 2006 | 07:34 PM
quicklook2's Avatar
quicklook2
the oil pan has middle age bulge.
Old Apr 16, 2006 | 09:39 PM
someday's Avatar
someday
the only thing that i can think of that could not be original is the dipstick, but if i remember correctly it has always had a varnish spot in the middle...this has been for a couple years ever since i started doing maintenance myself so i could be wrong if that is the right dipstick.
i never really checked the oil pan but it could have a big dent and never noticed or cared
Old Apr 16, 2006 | 10:33 PM
MRFIESTAS's Avatar
MRFIESTAS
It does'nt have a Ford oil cooler on it?
Old Apr 17, 2006 | 11:12 AM
someday's Avatar
someday
that doesnt explain why i initially need six qts to fill the pan after changing the oil
Truckpilot1329
2009 - 2014 F150
Oct 24, 2014 01:09 PM
jetch114
Mar 3, 2008 03:54 PM
Pickupman2004
May 10, 2007 05:01 PM
matt10461
Aug 15, 2005 02:04 AM
DTrain
Jan 20, 2004 05:02 PM
