1995 5.0L Engine Oil Capacity
Old Jan 19, 2004 | 07:59 PM
DTrain's Avatar
DTrain
I bought a 1995 F-150 4x4 and have a question regarding the engine oil capacity. The original owners manual listed the crankcase capacity at 5 Qts with a footnote that says "Add 1 quart for filter replacement."
I bought 6 qts of oil, did an an oil change including the filter, but after adding 5qts, I ran the engine for a while, let it set, and checked the dipstick. It was right at the full mark. I did not add the 6th qt.
Is the book wrong, or does it really take 6 qts? If it takes 6 qts, any thoughts on why mine would have showed full after 5?
Thanks,
DTrain
Old Jan 19, 2004 | 08:06 PM
Salmonhead's Avatar
Salmonhead
Good question, my 96 Bronco is the same way. Hey Ford tech's help us out! Does it need 5 or 6 qts with the filter? Is the dipstick just wrong?
Thanks
Old Jan 19, 2004 | 08:33 PM
Duderoy's Avatar
Duderoy
Well I looked it up in the Haynes manual and it to says 6 quarts with filter, but I have never put in more than 5. Very good question.
Old Jan 19, 2004 | 08:49 PM
GENEUS's Avatar
GENEUS
All the ford 4x4's I owned , took 6 qts.
w/filter chg.
78 F-150 400cid c-6 auto
84 Bronco 351w H.O. c-6 auto
85 F-150 351w H.O. aod
Old Jan 20, 2004 | 05:02 PM
stein78's Avatar
stein78
That's funny that you ask that. That's the first question I had when I purchased my '95. I just put in 5 quarts, it brings it right to full. Not sure what the deal is, I checked and my dipstick is the right size... So, I just put in 5 quarts and call it a day.
John Baker
Sep 19, 2018 02:25 PM
tcr1016
Mar 23, 2016 09:02 PM
ironhead86
May 17, 2011 01:48 AM
supercab78
Aug 6, 2006 11:25 AM
seebeew
Modular V8 (4.6L, 5.4L)
Jun 21, 2003 04:05 PM
