painting frame
Old Apr 13, 2006 | 10:24 PM
60'BigBlue's Avatar
60'BigBlue
painting frame
what is the best stuff to paint a frame with out to much prep work i know theres some paint out there that paints right over rust that dosent look half bad what is it called
Old Apr 13, 2006 | 10:35 PM
julie 54's Avatar
julie 54
painting frame
the one im thinking of is POR15 havent used it but read lotsa rave reviews about it! julie
Old Apr 13, 2006 | 10:40 PM
dylan1952's Avatar
dylan1952
I used POR products. I think it's Por-15 but remember the more prep. work you do the better the results especially over rust. Good Luck
Old Apr 13, 2006 | 10:42 PM
Brian_B's Avatar
Brian_B
My frame was cleaned (no idea how) and painted with eastwoods rust encapsulator. I didn't do it, but so far it looks fine. I haven't seen any rust popping up yet. Time will tell.
Old Apr 13, 2006 | 10:45 PM
60'BigBlue's Avatar
60'BigBlue
i know the fact of the matter is no matter what your doing its all in the prep work
Old Apr 13, 2006 | 11:59 PM
WillyB's Avatar
WillyB
If rust is a big issue you should strip it down and make sure the frame is solid.
On my 59 frame rust was not a problem - I used a cup wire brush on a 4" grinder to clean and knock off the worst, then painted it with semi-gloss black enamel. I used Rustoleum brand as you can apply it over rusty iron.
Old Apr 14, 2006 | 07:44 AM
HOTWRENCH's Avatar
HOTWRENCH
Talking
Google Magnet paints there's a product called Chassis Saver that does a
excellent job.
Have a good day---------Hotwrench
85blackbeauty
20
Jan 29, 2015 03:52 AM
Bessie
32
Jan 21, 2011 10:44 PM
mlevario99
13
Jul 10, 2007 03:03 PM
bucks77ford
Jan 8, 2006 07:26 PM
Rancho*Ryda
Paint & Bodywork
Feb 14, 2005 08:50 PM
