I think silver would be fine on a frame. A good base coat-clear coat with a couple extra coats of clear should work fine. Yes, it will get chipped up, but it's faily easy to touch up. Powder coating is of course harder to chip, but very difficult to color match on touch ups. Even powder coating will chip.
Cheap alternative - Tremclad makes a silver/grey roof paint for tin roofs on old houses. Specially formulated to sit up there on a boiling hot or freezing cold steel roof and take the elements.
Look at Rust Bullet, I just did my frame with it and then topcoated it gloss black but they say you don't need a topcoat, I almost left mine silver, it looked pretty good.
i'm doing a frame off to my 78 and was told by a fellow member to look into the DURABAk coatings. i might be taking this route myself instead of having rhino lined.
Silver huh? I would paint your frame with any top-coatable paint of the best quality you can buy and just top coat with a compatible silver paint. I have yet to run into any aluminum/silver/chrome/gold paint that was any kind of duarable.
