Stud Size?
Old Apr 13, 2006 | 06:07 PM
Bullride_101's Avatar
Bullride_101
Stud Size?
I am needing help finding out the stud size of the studs which are used to bolt the eshaust manifold to the downpipe on the exhaust system. This is on the 300 L6 EFI 1987 engine. I talked to the Ford part's department and they said it would cost 11 bucks per stud and 9 bucks per nut. WOW, that is rediculous. I thought about just using standard bolts instead instead of studs, anybody have any opinions or help? Thanks
Old Apr 13, 2006 | 06:16 PM
Franklin2's Avatar
Franklin2
Did you check the local parts stores? They usually have a selection of studs. Sometimes you can look in the help! section and find them.
I would be better to use studs because:
The bolts will have a tendency to rust and get stuck in the manifold. So it will be difficult to get the exhaust off later on. A nut is usually easier to get off.
The threads in the cast iron manifold are easy to strip. So a stud works better since you do not disturb the threads when taking the exhaust off. They would be easy to cross thread while you are trying to hold the pipe up, and get one started.
Old Apr 13, 2006 | 07:52 PM
Chumbucket's Avatar
Chumbucket
Bolts
If you mean the bolts that go from exhaust to each maniford Napa has the 4 bolts and nuts in kit.The studs screw in and you get 4 brass nuts
Old Apr 13, 2006 | 08:51 PM
havi's Avatar
havi
I'll have the Roast Duck
to clarify, the help section is just that...the H.E.L.P. section. I got mine there for the walker downpipe-to-efi manifolds. Dealerships always charge more.
Old Apr 14, 2006 | 11:16 AM
300I6VAN85's Avatar
300I6VAN85
Bought a Falcon years ago dirt cheap because the owner stripped the threads off the exhaust manifold studs. The problem was the new exhaust pipe stuck too far past the flange. A ham fist could not make a good seal, stripped the stud threads and put the cars worth over the edge for him. The studs were rusted inplace and he could not get the studs out. I bought it, pulled the motor part way out untill I could get a small pipe wrench around the studs, and held my breath. I did use some penatrating oil. Luck was on my side and the studs came out. I always treat the exhaust studs with respect from that leason learned.
Take the extra step and clean out the stud holes with a thread tap. Take your time, start the tap with your fingers so you don't cross thread. Clean the holes out with air and or wd or brake cleaner. I use anti-seize lubricant on the stud threads. Retighten the nuts after you burn a tank of gas.
Old Apr 14, 2006 | 11:19 AM
300I6VAN85's Avatar
300I6VAN85
Take the extra step and clean out the stud holes with a thread tap. Take your time, start the tap with your fingers so you don't cross thread. Clean the holes out with air and or wd or brake cleaner. I use anti-seize lubricant on the threads. Retighten the nuts after you burn a tank of gas.
Old Apr 14, 2006 | 04:17 PM
1982fordf100's Avatar
1982fordf100
Just did this on my dads 1992 F150. We used 2 1/2 inch long studs. The size was 7/16 14. Cost 8 bucks for 4 new studs and 4 nuts. Should be able to get them at any local hardware store. They are regular automotive studs.
Old Apr 14, 2006 | 09:48 PM
5_labsownus's Avatar
5_labsownus
I found NAPA had the studs and nuts and all 8 pcs for $6.00. Ford could not get them for me! even tried to match them with ford stock!
Rod
Boombastic86
May 22, 2024 03:43 AM
RedOct85I6
19
Jan 30, 2021 11:11 AM
underthebridgejim
May 17, 2016 09:38 AM
SgtRauksauff
Apr 12, 2016 09:50 AM
MattyP10178
Apr 7, 2016 07:06 AM
