Brake switch problem, again.. sheesh
Old Apr 12, 2006 | 01:30 AM
tojoski's Avatar
tojoski
well, I have a stock pwr brake setup on my 66, with the brake switch on top of the master cylinder. It seems that it has stopped working again, this will be the 3rd or 4th time in about 3 years. Maybe the silicone fluid is killing it?
Im at the point now where i just want to plug that hole and put the switch under the dash. Whats the easiest way to do this? Fab a bracket for mine or a swap from another truck? I have access to a 72 parts truck
Joe
Old Apr 12, 2006 | 04:34 AM
jowilker's Avatar
jowilker
Hi Joe, I found a bracket and mounted it and a mid 70s switch under my dash. The later power brake setups use a plunger type switch over the pressure.
I doubt this helps much, but it will work.
John
Old Apr 12, 2006 | 06:06 AM
ddavidv's Avatar
ddavidv
A couple ideas on my disc brake swap how-to page:
f100 disc swap
Old Apr 12, 2006 | 09:17 AM
tojoski's Avatar
tojoski
Ahhh, i remember looking at your page a couple of years ago.. that final idea
you came up with was something i had tossed around in my mind
Thanks!
Old Apr 12, 2006 | 11:46 AM
Flyn66dtmn's Avatar
Flyn66dtmn
i installed the complete braket under the dash on my 66 from a 76 1/2 ton and it bolted right in. i did this to elimate the clutch petal as i went to a C-6 auto. i also changed out the stearing column from the same donor. sorry to say i dont know how it would fit if you still have the stock stearing wheel. just a thought.
Technoblake
Sep 19, 2018 12:08 PM
beckman
May 10, 2013 09:56 AM
laynrubber
Nov 27, 2009 07:10 PM
Gman75
Jun 17, 2009 01:01 PM
gearloose1
Electrical Systems/Wiring
Jan 31, 2007 07:06 PM
