Ford 8.8 Questions
Old Apr 11, 2006 | 04:32 PM
Tdvjensen's Avatar
Tdvjensen
Ford 8.8 Questions
I have a 1992 F150 with an 8.8 and I am doing a 4x2 to 4x4 conversion and I have most of this completed. I have 2.73 rear gears in the 1992 F150 and the rear end definetly needs to be rebuilt. I also have a 8.8 with 3.50 gears (which match the front diff that I put in) in the truck that I am getting the engine from, which happens to be a 1988. In the 1992, I do not have a speedometer pickup in the transmission, so I am guessing that the electronic speedo runs off the VSS in the rear diff. The 1988 diff also has the VSS in the diff, but also a mechanical speedo pickup on the tranny. Both trucks have the rear abs and both have the VSS on the diff. Will I be able to swap the diffs without having issues with my speedo?
Old Apr 12, 2006 | 10:12 PM
Thomasm67's Avatar
Thomasm67
I have a 87 F150 4x4 and my speedo runs off the Tcase.
Old Apr 12, 2006 | 10:52 PM
subford's Avatar
subford
You should be OK, I would use the 92 VSS as the plug may be differnt.
Old Apr 13, 2006 | 11:31 AM
andym's Avatar
andym
Yeah, it will work fine. Prior to 1992, the VSS only served the ABS computer. When they started using it for the speedo as well nothing changed but wiring. It's the same part even.
BTW, 3.50 is not a gear ratio for an 8.8" axle. You probably have a 3.55. Just so you know.
Travis Hughes
Mar 9, 2017 05:14 AM
chesster51
May 22, 2016 05:04 PM
cypressford
Nov 21, 2015 01:31 PM
buttz
1997 - 2003 F150
Jun 15, 2015 04:08 PM
erupert66
Oct 4, 2013 04:19 PM
