Sponsored by: Auxito
VSS?
Old May 26, 2015 | 04:46 PM
buttz's Avatar
buttz
VSS?
Hi I have a 97 f150 2wd 4.2. my speedo is working on and off, my overdrive button is flashing and its shifting terrible. I changed the vss in the top of the rear diff but no luck... is there another sensor I should change? or go back and start looking at the wiring to the on in the diff. she has 353k on her and was running great till this.
Old May 27, 2015 | 08:35 PM
buttz's Avatar
buttz
Update I've changed the sensor in the differential and the output one in the rear of the Trans but no difference...
Old May 27, 2015 | 09:23 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Now you need some diagnostics? What codes are stored?
Old Jun 3, 2015 | 12:18 PM
buttz's Avatar
buttz
its not throwing a cel, can I still get them? thanks
Old Jun 3, 2015 | 08:42 PM
enriched&beyound's Avatar
enriched&beyound
Not complete sure, but I think a trans code can be tripped without generating a CEL. The flashing OD button is signaling a trans fault.
to scan for codes you need to make sure the scanner is capable of reading transmission codes. Some of the Free scans at auto part stores may not , so ask before letting them try.
Old Jun 3, 2015 | 08:50 PM
f31951truck's Avatar
f31951truck
Check service bulletins for your truck. I remember some of the trucks had problems with the speedometer driven gear in the trans getting loose and causing erratic speedometer problems. Google technical service bulletins for your truck. Also, try to get an accurate code scan of the trans to see what code is there. If the od light is flashing there is a code. This may or may not fix both problems. Check the obvious things first, fluid level and condition.
Old Jun 15, 2015 | 04:08 PM
buttz's Avatar
buttz
So the vss broke when I tried to pull it out...I have no idea how to get the rest out, it broke off flush with the Trans ...
thegreatgate
Apr 14, 2015 12:05 AM
fkaster01
Mar 31, 2009 10:44 AM
derekmj64
17
Dec 31, 2007 08:19 PM
derekmj64
16
Nov 27, 2007 09:02 PM
rudedogii
1978 - 1996 Big Bronco
Feb 19, 2006 11:50 AM
